Rad-ical 3 weeks of waiting
#44
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by dragon084
why doesnt that radiator look as good on the car as it does out of the box?
Sleep, Taking off the fans would probably make things a LOT easier, I mounted my tranny cooler to the condensor only, but that was tricky enough to get the wire ties through and back through to make a loop. Taking off at least that one fan would help, but you'd have to jack your car up and get the plastic skid plate from underneath to get the other 2 bolts.
#45
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by SwervinCL
I bet your dying for the spring, huh?
Can't wait to see more bro.
Totally can't wait for spring, paint job comes in spring too
![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
Sleep, that battery is an everstart from walmart, they cost like $40. I use it as a spare battery just to move my car in and out of the garage. I have an optima yellow top, and that is my main battery, she's out getting cleaned and ready for her new terminals, charging wires, alternator and ground kit
#48
where is....
Originally Posted by ZeroCL
Haha, no. Took long enough for someone to notice. I just get bored easily and photoshop is my best friend.
#50
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by AznX TL
i thought you used a sharpie on your clear corner ![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
![Ghetto](https://acurazine.com/forums/images/smilies/ghetto.gif)
#52
Nom Nom Nom Nom
#53
W WHIP.
1 Post
No, just his corner bulbs and turn signals ![Ghetto](https://acurazine.com/forums/images/smilies/ghetto.gif)
#54
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by STL+3.0CL
Lookin good Black, glad to see your making some progress.
#55
(Mid-Atlantic)
(Mid-Atlantic)
Oh, I also wrapped my new rad hoses in steel braided sleeves, but the new honda hose clamps were too hard to get on with the steel braided sleeves in the way, so we ripped them off, oh well, at least i don't have to do the rest of the lines, like the fuel lines and pcv lines like i was plannin on doin.
If anybody wants to buy a steel braided hose kit cheap, pm me
#58
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by tman89544
You're radiator is zoshiney.
#59
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by Sleep_DEPRIVED_Sleeper
hey Chris, did you have to remove the fan to mount the tran cooler? (i know you put it on while the rad's out, but can you see if i need to remove the fan???)
P.S. what kinda battery is that?
Huy, thought of a trick for you. If you can't get the wire ties through easily, just undo the 4 bols holding the 2 brackets on the outside ends, take the 2 brackets that overhang the rad, and it should be able to just fall forward an inch or 2, be careful not to crimp the hoses in the back, but you shouldn't have to take the fans off then, you should be able to work them in and out of the condensor easier that way.
#60
Turtle Charged, Biotcch!!
Thanks bro, but i figured another way
I don't need to remove the fan assembly, just push the mounting ties that come with the kit through the AC and the rad. The ties will protrude past the fan blades, cap the ties and trim the extra lenght, it won't touch the blades... i'll post a pic of how it looks tomorrow...
#61
(Mid-Atlantic)
(Mid-Atlantic)
Nice, that's one way to do it, I just looped mine back through, so I figured leaning the rad forward an inch or 2 would work for people for future installs.
#62
(Mid-Atlantic)
(Mid-Atlantic)
Few newer pictures, gettin ready to straighten all the finds on the A/C condensor and take the tranny cooler off, and paint the condensor with radiator gloss black paint.
Also have the Skunk2 1.3 kg/cm high pressure rad cap.
Also found when they rebuilt my tranny, they put an external line filter on the tranny, this is between the tranny and my tranny cooler
Picked some of this up, since I was workin on the tranny lines
For Greg (Dragon) that said my new rad didn't look new, this is the rad
TLDude876
12-28-2016 03:18 PM
rockyboy
01-25-2016 06:00 PM
