quick ques for you 2.2 CL's
Old Aug 8, 2005 | 12:55 PM
CL SLeePeR's Avatar
I recently bought a '97 2.2, but I need a motor for it. The problem I'm having is there a couple different F22 motors out there, which do I need? F22b? Will the F22 from a 94-95 Acc work? I read that the 96-97 F22 has a crank sensor, is this another type of F22? I've also found an F22B1. In short what is the engine stamp say on your(s) '97 2.2 blocks? ie: F22B ,F22B1, F22A
Old Aug 8, 2005 | 01:03 PM
Slooo97CL's Avatar
forget the F series go H
Old Aug 8, 2005 | 01:22 PM
CL Platano's Avatar
Tristate ViP Crew
Word if you can afford the H22 get that instead but if not its F22B1...
Old Aug 8, 2005 | 01:44 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
do the h22 if you can, otherwise get the f22
Old Aug 8, 2005 | 02:33 PM
shineynitelite's Avatar
NAWWWWSSSSSS
these guys speak teh truth...
f22b1 (96-97) 300-400
h22a = muchos $$$$$ but its the perfect time for the swap.. everything bolts up perfectly.. you will regret not getting the h22 later on down the road
Old Aug 8, 2005 | 02:38 PM
CL SLeePeR's Avatar
Thanks for the replies, this CL will be stock for now. Get around ride.. The other 1st gen I have is a 3Liter, waiting for it's transplant and misc parts...
Old Aug 8, 2005 | 02:47 PM
NAWWWWSSSSSS
dont bother building that 3.0 you'd be better off building a f22b1
Old Aug 8, 2005 | 02:52 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
uh oh here we go again...
Hey btw what H22 bolts right up?
Old Aug 8, 2005 | 03:00 PM
NAWWWWSSSSSS
h22a..
and we arnt starting another 3.0 vs 2.2 becuase 2.2s are way faster yo
Old Aug 8, 2005 | 03:17 PM
(Mid-Atlantic)
Originally Posted by shineynitelite
h22a..
Old Aug 8, 2005 | 04:00 PM
CL SLeePeR's Avatar
h22a..
Not necessarily.... 3.5
Old Aug 8, 2005 | 08:32 PM
Dagreen's Avatar
h22
save the extra money and do the h22 all you need is the motor and not the trans so you will save money, or do a f22 with h22 head. good luck
Old Aug 8, 2005 | 09:10 PM
jandj2204's Avatar
MuayThai scrappa
atleast get a JDM f22..they arnt too expensive..I could get you one for around 500
Old Aug 8, 2005 | 11:17 PM
NAWWWWSSSSSS
what are the specs on that motor
Old Aug 9, 2005 | 02:44 AM
VXCL's Avatar
AWD Torque Monster
f22b1 is what u need or f23a anything. if you want to live up to your name better go h22 + bolt ons. or NOS the crap out of an f.
Old Aug 9, 2005 | 08:49 AM
(Mid-Atlantic)
Old Aug 9, 2005 | 10:05 AM
NAWWWWSSSSSS
woot
Old Aug 9, 2005 | 02:39 PM
CL SLeePeR's Avatar
Once again thanks for all your replies.. But the 2.2 is just for gettin around.. I am going to build the 3 Liter for performance. I already have the motor I'm going to swap into it.
VXCL I've asked you before, and you said it was very difficult and you didn't want to get involved in such a project. But are you willing to make another set of custom Headlamps like your last setup before you sold the CL?
What is the difference in the JDM F22?? And what is included for $500? Tranny? ECU? Wiring Harness? etc...
For NOW this is just a get around ride.. In the future something better than an F or H motor if it's still in good shape.
Old Aug 10, 2005 | 03:42 PM
CL SLeePeR's Avatar
Old Aug 10, 2005 | 03:43 PM
CL Platano's Avatar
Tristate ViP Crew
You can't build the 3.0 for performance without having a spare transmission lying around.
Old Aug 10, 2005 | 07:29 PM
sumdumguy's Avatar
a jawful a somethin awful
oye'..platano nice wheels
and to platano's comment
Old Aug 11, 2005 | 08:24 AM
ShavedH22CL's Avatar
fear and Loathing
Def go H Series they are smooth like ur moms thighs
Old Aug 11, 2005 | 09:41 AM
haiduc's Avatar
Moderator Alumnus
Will you please conduct yourself in a semi-mature manner?
If you insist on running off at the mouth, go do it in Ramblings, not here.
Old Aug 11, 2005 | 11:34 AM
CL SLeePeR's Avatar
Homie dont even take it there..
6spd, is the answer to that one..
What is the difference in the JDM F22 motor will it be straight bolt on?? What about an F23 straight bolt on?? And what is included for $500? Tranny? ECU? Wiring Harness? etc...
Old Aug 11, 2005 | 12:08 PM
bryanz3.0cl's Avatar
nothing
he might mean f20b which is the accord euro r motor, its basically a destroked h22 -more rev happy, better flowing head, higher comp.
also you could bolt the h22 head to your f23 block and have more displacement for way cheaper then a whole swap plus the benefit of more tq. and a higher revving motor. h22 head on your f23 block + k20a pistons cams and a good header=mid 14s with bolts ons, the possibilites are endless with the fseries contrary to what most on here believe...
Old Aug 11, 2005 | 04:11 PM
jandj2204's Avatar
MuayThai scrappa
F22b is a 160hp Jdm 4th gen Lude engine..It bolts right in and uses the stock ECU w/ no problem.
Old Aug 11, 2005 | 04:14 PM
jandj2204's Avatar
MuayThai scrappa
160HP@6800
148lb ft@5500
Old Aug 12, 2005 | 09:42 AM
CL SLeePeR's Avatar
And what is included for $500? Tranny? ECU? Wiring Harness? distributor? How many miles on it what year the motor is and warranty? etc...
I basically need a complete motor. If you could be give a breakdown or pic as to what is included we can go from there. Im trying to get a complete of a motor as possible.
I take it, it's SOHC, and can confirm that it's a straight bolt on no cutting this and that to make it work.
Thank you for your time.. Mike S.
Old Aug 25, 2005 | 02:30 PM
CL SLeePeR's Avatar
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
KBTypeS
25
Oct 1, 2015 04:49 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
