Question on Sportlines....
Old Mar 31, 2003 | 06:46 PM
Acura3.0CL's Avatar
DamnThisHobby'sExpensive!
i know most people have the pro-kit but i was wonderin...y?? i mean dont u have to get a camber kit anyway? so why not get the sportlines and lower it even more???
Im assuming im right, the sportlines drop it even more than the prokit??
If i have a 3.0, what would be better to get?
(seems like the prokit dosnt do a good job of lowering the back...always seems liek that back is alot higher...
(could anyone post a pict of a cl with the 2 different setups??? THANKS!!!
Old Mar 31, 2003 | 08:38 PM
r3mix3r's Avatar
Get the sportlines, you won't be disapointed. My drop sits perfect on my 18's wheel tucks and everything.
Old Mar 31, 2003 | 08:47 PM
CLTECH's Avatar
Honda Technician
ghander has pics of both. and that's not true about the back sitting higher. it's the opposite. the front sits higher than the rear, making it look a tad weird. but i got over it. and no, i didn't need to get a camber kit for my pro kit...if i had to do it over again, i probably would have gone for the sportlines just for a slightly lower stance. oh well.....at least it's lowered now
Old Mar 31, 2003 | 08:57 PM
ding069's Avatar
acura-cl.com OG
Any drop over 1.5" needs a camber kit. A prokit is just under, so camber can stay in specs. The sportlines are about 2" correct? Meaning that they DO need a camber kit, unless u want to burn through tires. I went with the prokit because of the camber woes. If i had to do it over, i would have gotten the H&R 1.75 front & 1.5" rear. It evens out the the problems that the prokit has, and makes the front sit about even. Have to get a camber kit for the front only i believe? The prokit is just high enough so that im not bottoming out everywhere.
Old Mar 31, 2003 | 10:49 PM
dennis's Avatar
I like the pro-kit because the streets in Hawaii SUCK!!! Otherwise I would have shelled out the extra money on the sportlines. The sportlines are a 2" drop. But remember when you get the sporlines you definitely need to get a camber kit and new shocks. Pro-kits are simple. Just slap them on and get a mild drop. I'd say it all depends on how much money you have and what condition the streets are in. The pro-kits are about $225. The sportlines are about the same, $225, shocks $600, and camber $300 with installation (I'm not too sure if the camber is the right price but it's somewhere around there).
Old Mar 31, 2003 | 10:57 PM
Acura3.0CL's Avatar
so your saying, if i get the prokit, i dont need to get a damber kit for the front OR back and i DONT need to get shocks?? i can ride on the stock shocks?????
Old Mar 31, 2003 | 11:01 PM
dennis's Avatar
Yes you can ride on stock shocks and no you don't need a camber. I'm doing that now and the ride is similar to stock. Maybe a little bouncy but no problems at all. Don't get me wrong though. Any kind of drop will wear your stock shocks out faster but for right now they will hold up for a couple years.
Old Apr 1, 2003 | 08:08 AM
MaCe's Avatar
fellow MASShole
i got the sportlines and tokico blues .. and its a bit lower than 2 also have the ignalls camber kit and that thing is almost maxed out in the front ( corrects to 3 degrees )
Old Apr 1, 2003 | 10:24 AM
CLpower's Avatar
teh Senior Instigator
I have pics of both i'll post later.
Also, w/ the prokit you "MAY" need shocks and a camber kit it all really depends. Some do some don't
Acura3.0- the reason alot of people w/ the 3.0 don't get the sportlines is the extra weight in the front lower's them about another .5" and it causes rubbing when you get on the car hard. I use to be able to just mash w/ the pro-kit but I can't do that in w/ the sportlines (but it prevents me from getting tickets!
Old Apr 1, 2003 | 11:19 AM
Acura3.0CL's Avatar
thanks soo much for the info!!! please post picts if u can....
anyone know where i can get the prokit for cheap?????
(oh, and how can i tell if i need to get a camber kit??)
Old Apr 1, 2003 | 11:32 AM
dulux's Avatar
you wont need a camber kit, just get your regular alignment done
Old Apr 1, 2003 | 11:45 AM
CLpower's Avatar
dulux, about 50% it seems of the members here needed a camber kit w/ the prokit.
personally i didn't need one. You won't know until you go and get an alignment done.
Old Apr 1, 2003 | 01:10 PM
dennis's Avatar
With the pro-kit I'm really happy with the rear. Looks good. But the front sucks. Too much gap there. You can look for yourslef on my www there's pic inside.
Old Apr 1, 2003 | 06:56 PM
Acura3.0CL's Avatar
see mines a 3.0 so its heavyer so it should help weigh it down some...so ive heard...
Old Apr 1, 2003 | 06:58 PM
dennis's Avatar
True...True
Old Apr 2, 2003 | 07:08 AM
1StGenCL's Avatar
958 & 991
heres the 2.2 pro kit I am like .1 degree of specs so i should get a kit My front tires were destroyed (one actually blew out) so im going to get one. not the best pic but...
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
