Question on clear coners?
Old Feb 24, 2003 | 12:21 PM
pony11372's Avatar
Does anyone know how to instal the clear coner lights i havent been able to put mines on.
Old Feb 24, 2003 | 12:36 PM
CLUofI's Avatar
337
the owners manual shows how to pull them out to replace a bulb, so just going one more simple step forward and you will be set.
Old Feb 24, 2003 | 01:17 PM
swclown's Avatar
4-8-15-16-23-42
you need a philips screwdriver -- one screw holds them in, but you have to go at it from an angle. there is a small hole on one side and the screw is in there (it's deep so you will need a relatively long screwdriver and it's gonna have to be thin enough to fit through the hole. once you unscrew it it will pop out. the other end is supported by a braket and spring. it goes back the reverse way -- it's not hard..the trick is finding the right screwdriver Good Luck!!!
Old Feb 24, 2003 | 01:23 PM
klepto's Avatar
Just make sure that you take the spring off the old one and put it on the new ones
mada51589
Jan 9, 2025 04:40 PM
The Machine
Sep 24, 2018 08:27 PM
Oakes
Wash & Wax
Nov 12, 2015 09:34 PM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
datadr
Sep 12, 2015 09:12 PM
