Question and Answer Thread
Old Aug 15, 2009 | 01:17 AM
  #201
hOnU's Avatar
Da HoNu
Originally Posted by Anhedonia
the 250 was with alignment. i think im just going to hold off and do it myself with a buddy on sunday, take the extra money im saving and invest in some new tires/wheels.
if $250 is with alignment then that sounds good to me..because i've been going to my tech for awhile now, anytime i need to adjust my height and get an alignment (x3) i get it for about $200.
Old Aug 15, 2009 | 07:43 PM
  #202
Anhedonia's Avatar
im just going to do the install my self, pay 80$ for an alignment.
Old Aug 16, 2009 | 03:14 PM
  #203
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
So my abs light keeps coming on, only when i start pulling forward which means it's a WSS. Does anyone know if an obd2 scanner can pull the WSS code and tell me which one?
Old Aug 16, 2009 | 05:59 PM
  #204
f22vtec's Avatar
hey um my abs has been on since i pu the 98 cluster in u guys think the reason its on is because its a 3.0 98 cluster or does that not have any effect on it?
Old Aug 16, 2009 | 09:57 PM
  #205
Gnate's Avatar
Custom User Title
Call me a hypocrite... just bought lowering springs.
Old Aug 16, 2009 | 10:02 PM
  #206
(Mid-Atlantic)
:shakehead
Old Aug 16, 2009 | 10:06 PM
  #207
Gnate's Avatar
Custom User Title
my bad I thought I clicked on the current project thread.
Old Aug 16, 2009 | 10:34 PM
  #208
Anhedonia's Avatar
im happy for you
Old Aug 16, 2009 | 10:52 PM
  #209
Anhedonia's Avatar
ok i thought i knew, but i guess i dont?
the higher the offset = further the wheel sticks out from the hub (and eventually past the fender?) right?
but heres whats confusing me, if you get a 17x7 with a 42 offset, and a 17x8 with a 42 offset, the 8 will stick out further correct? how do you compensate for doing that? for each inch of tire width, subtract its equivalent in MM from the offset mm? so 1 inch = 25.4 mm
that means that to have the same appearance, with a 17x8 as a 17x7, youd have to run a 17x8 with a 17mm offset? along the same lines as this theory, if you go to a 17x9.. then your technically at a -8 offset, does such a thing exist?
Old Aug 16, 2009 | 11:10 PM
  #210
mitch14's Avatar
CL in lawnmower status
^not quite right
first of all, if you mean the same appearance as how far the outer edge of the wheel will stick out towards the fender or quarter panel, then you have it backwards
if you want a 17x8 to be at the same measurement from the hub to the outer edge of the rim as a 17x7 +42 you'd have to add to the offset, not subtract
second portion where you got it a little mixed up
think of adding width, as adding it on both sides of the wheel
so if comparing a 17x7 +42 and a 17x8 +42 the 8 inch wide wheel will stick out 12.7mm(1/2 inch) more than the 7 inch wide on both sides
so to achieve the same measurement from the hub to the outer edge of the rim, the 17x8 would have to be 17x8 +55, it would be .3mm out further, but that's nothing really
and yes, there are many different offsets for wheels, especially when it comes to 3 piece wheels, although looking at most of the new cheaper brands you may never see some of these offsets
i've seen anywhere from a -70 offset, to a high 50's i believe
here's a pic to help
Old Aug 17, 2009 | 12:16 AM
  #211
Anhedonia's Avatar
ah excellent, i understood more then i thought i did.. but didnt explain it well. the picture helped lol i was thinking of it in opposite terms, didnt think of the half thing either.
thanks mitch
Old Aug 17, 2009 | 12:42 AM
  #212
Gnate's Avatar
Custom User Title
offset explanations never cease to confuse the fuck out of me.
Old Aug 17, 2009 | 02:00 PM
  #213
GhettoNinja06's Avatar
Skuuuurrrrrt!
Maybe someday that I venture out to buy some wheels I'll understand.
Old Aug 17, 2009 | 11:06 PM
  #214
mitch14's Avatar
thanks mitch
^no problem sir, glad i could help
if anyone else still has questions about the offset talk i can try and explain in PM's or whatever
just so we don't clutter this thread with the same type of questions
Old Aug 18, 2009 | 12:34 AM
  #215
Anhedonia's Avatar
ok ive got a question about spacers.. gnate and i were taling earlier and he brought up a good point. if we were to employ the use of spacers, would we need longer lug bolts?
Old Aug 18, 2009 | 01:11 PM
  #216
spencer_homer's Avatar
i like acura
not longer lug bolts. i dont quite know what your staying. you'll need longer studs pressed in if you space more than 7mm. and as far as lug nugs go, your probably better off with some open end tuner style lugs
Old Aug 18, 2009 | 01:44 PM
  #217
(Mid-Atlantic)
you will need extended studs, and open ended lugs
Old Aug 18, 2009 | 02:15 PM
  #218
Gnate's Avatar
Custom User Title
how much are extended studs to purchase and have installed?
Old Aug 18, 2009 | 02:20 PM
  #219
Josh99CL's Avatar
The studs themselves are inexpensive.
Old Aug 18, 2009 | 02:52 PM
  #220
(Mid-Atlantic)
Q&A thread, the replacement for searching
Old Aug 18, 2009 | 02:58 PM
  #221
Gnate's Avatar
Custom User Title
Question: Would you rather me start another thread when i'm too lazy too search? :gheyfight
jk. But this thread is nice for that reason.
It's great, it saves clutter and allows n00bs to ask questions without posting a million new intake threads too!
Old Aug 18, 2009 | 03:17 PM
  #222
(Mid-Atlantic)
no one searches anyway, was just making a joke
But I would rather you searched
Old Aug 18, 2009 | 03:18 PM
  #223
Gnate's Avatar
Custom User Title
Next time, promise.
Old Aug 18, 2009 | 05:44 PM
  #224
Anhedonia's Avatar
yeah, lug bolts, studs, same difference hahaha.. ok so need it if you space more then 7mm? psht, im looking to space 3/8th easy so that answers that question.. how difficult could it be to swap out the studs?
Old Aug 18, 2009 | 11:33 PM
  #225
i like acura
it would be hammering the shit out of them. you have to take them to a shop and have them pressed in with a stud press
Old Aug 21, 2009 | 11:21 PM
  #226
Anhedonia's Avatar
anyone know how wide our trunk is in inches?
Old Aug 22, 2009 | 11:10 PM
  #227
(Mid-Atlantic)
Depends on which part of the trunk, gets narrower by the shock towers and wider by the tail lights
Old Aug 22, 2009 | 11:25 PM
  #228
Miiike's Avatar
i've searched but i just want to be sure here, will an F22 5 speed tranny go fine with an F23? mines auto right now but it's going out the door...again, and i can get the 5 speed from an accord parts and installed for cheaper than a rebuild, would that work or will certain parts need to be from an f23?
Old Aug 23, 2009 | 01:53 PM
  #229
Anhedonia's Avatar
it will bolt directly up, youll just have to get all the necessary parts for the auto/manual swap as well. and of course, whether or not you chose to keep your auto cluster.
Old Aug 23, 2009 | 02:03 PM
  #230
Anhedonia's Avatar
ok now im kind of confused.. i was just chekcing out the bisimoto website looking at cam shafts.. it says you can send yours in to have it reground/ hard welded, or purchase a core to do the same. the core costs 150$ and is honda OEM.. but does that include the price of the grind? or is that simplyfor the core? theres also no specs listed for the service performed if i send it in.
Old Aug 23, 2009 | 02:42 PM
  #231
YtseJammer's Avatar
Low and Slow
Does anyone know where I can get a replacement spring that goes behind the front corner lens housing? It's the spring that keeps it from popping out. The spring came off of my drivers side corner and now the housing keeps falling out when I drive around.
Old Aug 23, 2009 | 03:44 PM
  #232
Anhedonia's Avatar
lol came thing happened to me.. honda sells it for 4.79$ or you can hit up your local hardware store and pick one up for half that.
Old Aug 23, 2009 | 03:57 PM
  #233
YtseJammer's Avatar
Low and Slow
guess i need to drive down to the dealership because all the ppl at the hardware stores acted like they had never seen that part before.
Old Aug 23, 2009 | 04:39 PM
  #234
(Mid-Atlantic)
Try emailing or calling them and asking what their price includes
Yeah, that spring has a screw hole bent into it, I'd just go to the dealer and get one, I got a new set from www.acuraautomotiveparts.org but you have to order so much for them to ship it, like $30
Old Aug 23, 2009 | 04:53 PM
  #235
YtseJammer's Avatar
Low and Slow
What is the part called? I couldn't find it on the aap website. I was thinking about buying a new splash guard and fender liner too.
Old Aug 23, 2009 | 06:23 PM
  #236
YtseJammer's Avatar
Low and Slow
I found it. They want $10 for them and you have to buy at least 2.
Old Aug 23, 2009 | 11:25 PM
  #237
Anhedonia's Avatar
dude i work in a hardware store, we have springs like that lol, theyre labled as trampoline or screen door springs..
Old Aug 23, 2009 | 11:26 PM
  #238
Anhedonia's Avatar
hmmm. this might work !!
but i know somebody was just recently dealing with them.. gnate?
Old Aug 24, 2009 | 12:40 AM
  #239
YtseJammer's Avatar
Low and Slow
Went to Home Depot and bought a whole box full of them for $4. They don't fit perfectly, but they still do the job.
Old Aug 24, 2009 | 11:29 PM
  #240
kmatthe2's Avatar
I have some noob questions here.
The NOOB buide says CAI for the 1g 3.0 CL are from the 1998 Accord 3.0.
So if I purchase say the AEM V2 cold air intake system for the 98 accord 3.0 I will not have to do any customization or bending or anything correct?
And another noob question once i attach the CAI to the engine I still keep the stock air filter set up correct? Im just making sure the CAI is a supplement to the stock air filter system and not a replacement?
