Question and Answer Thread
Old 07-25-2010 | 09:26 PM
  #641
DaInFaMMuS1's Avatar
Your ECU is probably adapting to the new intake and has programmed accordingly for the increase in air to smooth your acceleration.
Old 07-26-2010 | 08:52 PM
  #642
Swizzi Pea's Avatar
Is there any way to get the throttle response back?
Old 07-27-2010 | 08:09 AM
  #643
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
seafoam, and also look into cleaning your EGR valve
If those don't help, you could try tightening your throttle cable
Old 07-28-2010 | 01:21 AM
  #644
magi302's Avatar
vtecluv
well...my opinion is to get Injen piping, Swain-tech.com white Lightning coat it, and mount Apexi filter outside the ehgine compartment/ Very pricey all together, but really powerful and fantastic sound! Moving the battery to the trunk (Optima) frees up lots of space for oil catch can, external coil, etc. Be sure to use 1/0 flexible wire to ensure enough juice and ground it with size 1 back up to the same grounding spot.
Old 08-04-2010 | 11:06 PM
  #645
South Jersey CL's Avatar
question.
its been my understanding that LEDs are supposed to last for a long time/never burn out. however, recently many of mine have started to flicker/crap out on me all together. these include license plate, cig lighter, ashtray and 80mph LEDs. all have been from superbrightleds.com
so is that website just sending me shitty products or is there an electrical problem with the car?
i replaced the battery in june, so its not that.
any input is greatly appreciated, as this issue is starting to piss me off.
-steve
Old 08-05-2010 | 08:17 AM
  #646
(Mid-Atlantic)
I've never had an issue with SBLed's bulbs, and I have bought several hundred dollars worth, and have them in both of my cars, and gave my old bulbs to a friend and he never had problesm either, I would definitely point to an electrical issue of some sort
Old 08-05-2010 | 04:03 PM
  #647
bRunCL's Avatar
question for anyone who has drained and filled their radiator (not the block): Is it necessary to raise up the front of the car? it seems like i can get to the drain plug when its on the ground so im trying to avoid any unnecessary work. Any input?
Old 08-05-2010 | 11:06 PM
  #648
(Mid-Atlantic)
As long as you can reach the lower drain plug, no need
Old 08-09-2010 | 03:50 AM
  #649
2.2vtec's Avatar
6th Gear
i not sure if this is against the rules, but i was just wondering i cannot find the function and form type 1 coilovers, any help?
Old 08-09-2010 | 07:11 AM
  #650
Miiike's Avatar
^ Not sure if they're still for sale or not, but 732xghost was selling some a month ago
Old 08-09-2010 | 05:28 PM
  #651
2.2vtec's Avatar
6th Gear
yeah he sold them already :/ thankss tho
Old 08-09-2010 | 05:30 PM
  #652
mitch14's Avatar
CL in lawnmower status
header exhaust ports on a 97 2.2cl 5spd...
are they 0--00--0 or 0-0-0-0?
just wanted to make sure, i can't see because i still have factory heatshield on.
hopefully it is 0--00--0, cuz i just bought one
Old 08-09-2010 | 06:28 PM
  #653
f22vtec's Avatar
our motor (f22b1) goes like 0_00_0 the non vtec is 0_0_0_0 that's why the non vtec motor can use a dsm turbo and we can't.
  #654
f22vtec's Avatar
if ya want look at my old pics there's a pic of my dc sports.
Old 08-09-2010 | 11:33 PM
  #655
mitch14's Avatar
prefect, thanks for the info, yeah i think i saw a pic of yours, just wanted to make 100% sure before i make an appointment at an exhaust place to get it all done
BTW these are what i bought.
just cheap ones on ebay, but should be better than my probably leaky as fuck ones
Old 08-16-2010 | 11:08 AM
  #656
MrRecall3's Avatar
ok two things....
1. I just did a tune up and oil change drove to maryland now my service indicator is yellow? It was green when i left and came back and its yellow?
2. This abs sensor noise is really embarrasing when you turn the car on! smh where can i find one cheap NOT the $1000 that the dealer wants for a part for a 13 year old car! please help!
Old 08-16-2010 | 11:46 AM
  #657
f22vtec's Avatar
mitch save the money and do it your self it's so easyy!
Old 08-16-2010 | 12:09 PM
  #658
Originally Posted by MrRecall3
ok two things....
1. stick your key in the slot next to the indicator light on your gauges, it will go back to green.
Old 08-16-2010 | 02:52 PM
  #659
(Mid-Atlantic)
ok two things....
1.) The service indicator goes by mileage, just reset it
2.) The noise is your abs pump priming, it just happens. You can find the abs module on ebay for cheaper than 1000.
Old 09-15-2010 | 02:28 PM
  #660
GOLDNSPOTS's Avatar
Mechanically Challenged
I'm thinking of painting my valve cover this week. Do I need to buy new gaskets and seals?
Old 09-15-2010 | 02:40 PM
  #661
(Mid-Atlantic)
you don't have to, but it is a good idea
Old 09-24-2010 | 12:16 PM
  #662
YtseJammer's Avatar
Low and Slow
You might as well replace them. I got a kit online for like $25. Ended up tearing one of my seals when I was taking everything apart so it was good I had the new ones.
Old 09-24-2010 | 02:06 PM
  #663
on1wheel01's Avatar
Where is the abs sensor located at? I saved the thing under the hood that all the brake lines goes into from my old parts car. What is that thing called
Old 09-24-2010 | 02:25 PM
  #664
(Mid-Atlantic)
That's your ABS modulator, there are 4 ABS WSS (Wheel Speed Sensors) one on each wheel
Old 09-28-2010 | 10:12 AM
  #665
brice.hayden's Avatar
i'd get accord mirrors honestly. thats what i plan on doing
Old 09-28-2010 | 10:55 AM
  #666
MrRecall3's Avatar
what year accord?
Old 09-28-2010 | 04:30 PM
  #667
94-97 coupe. not sure if the sedan ones will work.
Old 09-29-2010 | 08:29 AM
  #668
(Mid-Atlantic)
Please take all part requests to the Private Sales / Black Market area
Old 10-19-2010 | 12:40 PM
  #669
bRunCL's Avatar
Is anyone familiar with checking the ATF level in the tranny? I've tried using the dipstick and it cant get a definite level. My real question is i think I might have too much ATF in the tranny. When i look in the dipstick hole while the car is running, (after it has been warmed up for 20-30 mins) I can see the fluid bubbling. Im thinking this means there is too much???
Old 10-19-2010 | 01:35 PM
  #670
(Mid-Atlantic)
sounds like too much, from what I understand you're supposed to check the fluid while the car is off
Old 10-19-2010 | 05:52 PM
  #671
bRunCL's Avatar
Thats what I was thinking too, it seems like too much. I have a small leak at the axle seal and have been slowly adding fluid over the last 2 years but I think ive been adding too much....And im gonna try checking it with the engine off and see what kind of reading I can get
Old 10-27-2010 | 03:28 AM
  #672
mlg61532's Avatar
3rd Gear
My tranny is about to give. Anyone know if I'd b able 2 put a 3.2 type S 5speed tranny on my 3.0 Cl
Old 10-27-2010 | 08:35 AM
  #673
It'll be difficult to do so, Just go with the 3.0 or if the bell housing will line up, the 07 odyssey tranny is what the 2nd gen 3.2 guys use to replace their blown trannies since the valving allows for better clutch lubrication.
Old 11-30-2010 | 08:26 PM
  #674
Question
I'm hearing a knocking sound that sounds like its coming from the front of the car. The car knocks when I press the brakes (after about a minute or so of not pressing them), and it also knocks when I'm accelerating out of a complete stop (in first gear).
What is causing this noise and where is it coming from?
Thanks,
Steve
Old 12-01-2010 | 08:18 AM
  #675
(Mid-Atlantic)
Steve, when I had this problem it was my shock tower bushings disintegrating
Old 12-04-2010 | 03:29 PM
  #676
Thanks Chris, I'll have it looked at.
Also, another question.
My gf has a 97 Accord coupe (with only 41000 miles on it). We were driving yesterday and she is listening to the CD player (stock) and when she put a new CD in, it gave her the CD-PEO code. So I clean the disk and put it back in, same thing. We try a few different CDs and CD-Rs and still the same code pops up. I'm guessing her CD player is done for?
Old 12-05-2010 | 01:05 PM
  #677
mattastick's Avatar
Sounds about right with the CD player. I was going to ask if you were trying to play CD-R's and CD-RW's because some stock decks won't play those, but you covered that. I'd guess the deck is the problem, but try the CD's in a different car/deck, just to make sure they're still good.
Old 12-06-2010 | 03:17 PM
  #678
thats what i thought...i pulled the CD out of my stock CD player and tried in hers in it didnt work. def. the CD player. thanks bro.
Old 12-06-2010 | 05:12 PM
  #679
bRunCL's Avatar
That happened on my cl. The discs started getting really hot after playing, then that error would keep showing up. gave me reason to install a headunit lol i remember searching this a while ago and it seems to be a pretty common problem on hondas/acuras
Old 12-08-2010 | 12:03 PM
  #680
Another problem with the car.
When I'm slowing down it sounds like something is rubbing in the front of the car. You can especially hear it when pulling into a parking space. It happens when I'm downshifting or in neutral. It's sort or a knocking/rubbing sound that slows in tempo when the speed slows, obv.
Car's going in for surgery on Friday, but can anyone diagnose her ailment?
Quick Reply: Question and Answer Thread
