Question and Answer Thread
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
This thread was requested by members of this forum.
This thread is specifically for asking and answering questions about your car.
This thread is meant for 1st Gen CL related questions only, this is a car forum, use it to ask questions about your car.
No off topic conversations will be allowed.
The format of this thread is that someone asks a question that they need a quick answer to. People can chime in with HELPFUL USEFUL ANSWERS
This thread will be monitored and moderated, however don't make it difficult for us. We don't want to have to keep this thread clean or have to be deleting useless BS or rambling off topic discussions.
If you don't have anything to add to the current running discussions or questions,
do not post here or you will be in violation of the rules and dealt with accordingly.
No parts requests
Abuse of this thread will lead to closure or deletion.
Please respect your fellow members and please respect the rules, let's make this a useful resource.
nwkFatBoy (04-28-2013)
(Mid-Atlantic)
(Mid-Atlantic)
Post a question that you need to know, and we can respond back with answers, please read and obey the rules
i'll start it off I guess.
Does anyone know if there is a manual steering rack of any other honda that us members w/deleted power steering could use instead of the power rack? Or is that impossible unless custom made?
1 Post
^ after doing some looking into that.. my best guess would be to try and find an accord one from the pre-power steering days. i think an 87 and below should do the trick if what i was looking at is correct. what i couldnt find is if there was ever an F/H that had non power steering.
Runs on Dunkin
For a CAI, what size inlet should the filter have to attach to the pipe? I need to know so I can order the K&N along with the ebay intake. Thought I asked before, but not sure.
They make them in all different sizes. Be careful, I was about to order a filter for my pipe, but decided to double check it to be sure. It was 2.5", not 3" like I assumed. If you're ordering the pipe and filter from different places, make sure it lists how big it is in the description.
Boats and Hoes!
the main sign is slippage, and the easiest way to test for it is to apply the brakes in 2nd or 3rd gear at around 3k rpm and floor it but push on the brakes to the point of slowing the car down and lowering the rpms, and if the rpms raise then it's slipping and on it's way out.
Another possible sign would be if it chatters alot upon taking off
Oh btw I'm on the original clutch at 155k miles and still smooth with no slippage
HovaIsHigh
Is the inlet size on our throttle body 3 inches, and is there a power difference when getting a 2.5 inch intake opposed to a 3 inch? I KNOW MORE COLD AIR IS BETTER.
what distributor & ecu should I look for for the non-starting jdm f22b swap in my car currently? lack of CPS down low under the timing belt cover tells me the block is obd1...
and can I mod / hack the wiring on my CL dizzy? if so, how?
(Mid-Atlantic)
(Mid-Atlantic)
I believe the Tb on a 3.0 is 3" I have a 2.75" CAI tube on mine with a 2.75" filter and bypass valve, 2.75 is pretty standard for our engine
HovaIsHigh
OK Sounds good, so if I order a AEM v2 for our car, it is recommended to say f--- it to the aem filter that comes with it and just by a K/N 2.75 in Cone to prevent hissing. I'm having that go on right now and cleaning it didn't help. Sounds like a mini turbo lol...+15 HP
(Mid-Atlantic)
(Mid-Atlantic)
AEM V2 is a waste, just get an ebay intake and put a k&n filter on it
Yes, you need a filter that has a 6" opening. If you want a K&N filter, BPi offers the velocity stack and filter together. Personally, I was looking into dryflow filters. I'm sick of this oiling shit.
Boats and Hoes!
Yes, but it will be quite a bit smaller in overall diameter and will look dumb without a substantial drop, and even then I'm not sure it will look good.
And that tire would fit a 16x8 or 16x7 wheel, and it would even fit the stock 16x6 but it's a bit of a stretch, I've put 225 series on 16x6 before though and ran them for thousands of miles with no problems. In fact, I think someone on here is running 225/50/16s I believe on stockies, can't remember who though.
A good size for calculating tire diameters between different sizes is:
http://www.miata.net/garage/tirecalc.html
Boats and Hoes!
Runs on Dunkin
Anybody on here have experience with Skunk2 suspension parts? I'm looking at their Sport shock kit and just wanted to know before I would jump on a good deal....
(Mid-Atlantic)
(Mid-Atlantic)
Just one thing to add guys, quote the person who you're responding to or answering
(Mid-Atlantic)
(Mid-Atlantic)
My PU bushings never squeaked, and my car has sat for a couple years since putting them on there, I would say lube them more
(Mid-Atlantic)
(Mid-Atlantic)
I found these HIDs online for 36.99 http://www.vvme.com/product/detail-20023.html
since theyre so inexpensive do you think i'll have many problems with them? or should i just get a more expensive set?
(Mid-Atlantic)
(Mid-Atlantic)
I def like my d2's so far, still need to adjust the shocks but I dig em
meh, you get what you pay for, I think you'd be better off with the guy in the gb thread for $60 at least he has a warranty
