Question about subs.... and ohm load
Ok so the amp I want says 125x2 RMS @ 4 ohms
The subs (JL 12W0) also handle 125 watts RMS each at 4 ohms
does this work? or would it not work because the total ohm load for the subs is 8 ohms
Then, I emailed this guy on his ebay auction for 2 8-ohm subs. he said the total ohm load for 2 8-ohm subs is 2 ohm.... that totally confused me. The more ohms the more resistance right? So it would be better to have less resistance right?
Any help would be greatly appreciated. Thanks.
go to www.crutchfield.com i think there is a description of wiring techniques and ohm loads
or maybe www.howstuffworks.com
ohm depend on how they are wired.
you have 2 4 ohm subs,
wired in series you would have 8 ohms
wired in parrellel you have 2.
each wired to their own channel would give 4 on each channel
crutchfield application only applies to mono amps. you have a stereo 2ch amp.
once again:
if you have (2) speakers wired to 8ohm each, then bridged on your amp, you will have 2 ohm load
if you have (2) speakers wired to 4ohm each, then bridged on your amp, you will have a 1 ohm load.
this is for 2ch stereo amps.
once again:
i found a good link http://www.jlaudio.com/tutorials/wiring/index.html
From amp: right+ -> left speaker+ then left speaker+ -> right speaker+
From amp: left+ -> left speaker- then left speaker- -> right speaker-
This is how 95% of amps bridge. This will give you a +2ohm load from the amp to a -2ohm load that the speakers provide! Problem solved assuming you want to bridge them (which you do. Stereo subs sound SHITTY!)
P.S. if that amp does not say bridgeable anywhere in the instructions DONT DO THIS! If the amp is not bridgeable (which means it can be made from 2 channels [stereo-like normal speakers] to 1 channel [mono-like subs]) then don't buy the amp. Only a bridgeable amp is intended for subs.
this is even confusing for someone that knows how to wire this up.
heres the amp and subs im looking at... anyone have any suggestions?
amp:
http://cgi.ebay.com/ws/eBayISAPI.dll...category=39736
subs:
http://cgi.ebay.com/ws/eBayISAPI.dll...category=39771
amp:
subs:
Most amps bridge by reversing the polarity on one channel and floating the ground. Therefore, you wire the sub to both of the (+) sides of the amp, and DO NOT USE the (-) side!!! You could fry some stuff! I have seen a few amps that just reverse the polarity at the outputs, and you use the (+) on one channel, and the (-) on the other channel.
Those subs and that amp don't really match.
i would not buy that amp. warranty is done on that. plus, pioneer amps dont do shit for subs. the speakers also dont look that good.
spend a few extra dollars and buy new; used inexpensive stuff will sound like used inexpensive stuff. save your self the headache of used car audio.
I wouldnt go with the w0's they pretty much suck in my opinion id save up and do it rite the 1st time. My best advice go to a local car stereo shop and listen to different amps matched up with subs. When you find something you like get all the model#'s, research the net see if its cheaper. If it isn't just buy it from the stereo shop. Go with what fits both your ear and your buget.
first, that amp is not enough power for subs. second, that amp is about 2-3 year old model. no manufacture warranty. new models are going for like $50 more, more wattage. the subs are below mediocore.
All 2 ch amps should be bridged to mono for sub applications to ensure the highest output and to ensure the matching level of the subs. The amp you choose is 380 watts @ 4 ohms. The subs you choose are 4 ohms each. The two subs in parallel would equal 2 ohms, a load too great for that amp (IE you'd burn the shit up). You could wire the subs in series, which would equal 8 ohms but that would pull you down to only 250 watts. You need an amp and sub combo that matches impedence.
Originally posted by dennis
I disagree. I think the W0's are awesone for the price you pay. I had 2 12's and they slammed harder than most of my friends subs. They only say 125W RMS but I think it can push a lot more than that and still sound good.
I had 2 JL w6's in my car with a 3000w Boss Class-D Amp.. (Yeh it doesnt push out 3000w supposdlly untill half an ohm).. Im sure its not pushing close to 3000 at half either, but thoose hit HARD and great quality subs.. youll never go wrong with JL's..
Originally posted by green972.2
so... ok if i wired the 2 4-ohm subs in paralled i would get a 2 ohm load. How many watts would be ideal for a mono amp to be pushing in that situation?
Yes sir it would work, but for those subs you want a bigger amp. Look for something at least 400W. I know people on here have put these subs down, but trust me. You wouldn't be ashammed to have W0s (unless the previous owner beat the hell out of them). But you will need at least 400W to get sound out of them. 250W would almost not even move the cone
I'm good with this subs and ohmage stuff so if you ever need info you can pm me!
so they say they handle 125 watt rms... so would it be good to get a 250x1 @ 2 ohm mono amp?
They really shouldnt blow unless you put a actual compertition amp to it..
I was running 2 12'' w6's and their rated at 325 rms..or so
and I had a monoblock 3000w D-class on them.. and I could turn it up till my speakers distorted without a problem..
JL's are very good for durabilty and power..
so was i.... this thread has helped alot..
so wat do u guys think of 2 8 ohm subs wired in parallel with this amp:
MTX Thunder 282
http://cgi.ebay.com/ws/eBayISAPI.dll...&category=3281
MTX Thunder 282
I was too lazy before.
Here. Just about everything you need to know about wiring your subs.
MTX Thunder 282
MTX Thunder 282
I also have a 6500D that's 775x1 hehe.
