Pulleys BAD?!?!
Evolution
Pulleys BAD?!?!
I have been searching to find out how to install my AEM Pulleys and came across this at accordv6.com:
Pulleys They said that their AEM pulleys put a strain on the alternator after a month, causing it to malfunction and burn up batteries. I have already gone through 1 alternator and replaced it with about a 160-180 (110 Stock I think??) Will this cause problems for me?
Anyone else have problems?
blah blah blah
I just put in UR PUlleys into my car a little more then two weeks ago. I have a system also. Car seems to be running just fine. LOve those UR pulleys. quick revs and smooth shifts....should look into it at v6accord forum. That's where i got all my info from...UR has the crank pulley.
AWD Torque Monster
the main prob seemed to be v6 cords with american alternators instead of denso. in theory the pully will make ur alt last longer cuz it is larger and will rotate less, but depending upon how much power u draw u can damage the alt, but thats only at idle. both the aem and oem pully make bout the same power 1500 rpm and above. the 3.0 cl does not seem to share that problem with the v6 cords so dont worry. u do however have to unbolt one engine mount and lift the engine slightlt to install the new belts.
Evolution
I am about 99% sure that I have a Delphi alternator (which they had problems with) is it still worth the risk?
Who has installation tips/how too? Torque Specs? And Pics of the install pulleys?! I would really apprechiate it so I can get them on before my dyno!
I have the AEM alternator and power steering pulleys with UR crank pulley. They been on for nearly a year now with no problems. I've heard using an air tool to install the pulley can damage the alternator. Just torque it by hand and you should be ok.
