problem putting in gauges
hey, i found the post on here that had instructions for putting in new gauges. well i tried and didnt get very far at all.
i took out the cruise control thingy real easily but the dimmer control will not come out. i cant even pull it out far enough so i can unplug it or disconnect it. can anyone please tell me how to do it. i tried for half an hour and couldnt get it. it gets really annoying when u cant do something so easy
Still trolling
Remove the lower dash under the stearing colum. It just snaps on. Then unbolt the metal panel (4x10mm bolts).
You might be able to reach up there after that to help pull it out.
My indiglos are here tomorrow, so I will install them as well and take pictures for a how to.
ya i broke my temp needle =(
but just be careful, and maybe use a screw driver to help push the little thing down while u pull, it should come off, I was able to do it without removing the whole dash
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
brandnewcolony
09-12-2015 10:39 AM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
