positives of obd1 conversion?
Old Oct 1, 2004 | 11:46 AM
sally's Avatar
What are the positives of doing an obd1 conversion?
Old Oct 1, 2004 | 12:02 PM
DrDre1443's Avatar
112K and on 1st tranny!
? didn't know you could "convert"?
Old Oct 1, 2004 | 12:04 PM
xrunner86x's Avatar
A-CL Totaled Member
Pro: You can run a chipped/programmed ECU.
Con: Only uses 1 O2 sensor and the OBDII diagnostic plug won't work, so you cant pass emissions in some places. Also, by the time you add up the ECU, chip, tuning, harness, and other rewiring that is necessary, it is really expensive. EMS would be cheaper.
There is no reason to do it unless you have serious mods and need a fully tunable ECU, and then the EMS would be a better option.
Old Oct 1, 2004 | 12:20 PM
Mark Davison's Avatar
Big Block DOHC Type-R
Converting to obd1 is easy. Get an obd2 to obd1 jumper $250; obd1 ecu $200; socket and program, mabey $50. An EMS could cost up to $1500.
Old Oct 1, 2004 | 02:50 PM
sally's Avatar
will an apexi vafc work for an average or higher moded car?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
