PLEASE HELP! Dash and head lights flicker when turn signal is on
I have a 98 CL 3.0 and I have had this problem for a year now. When I got the car a year ago I notice that when I use my turn signal, all my dash lights and headlights blink and surge as if there was a short. Now I need to fix it because it is getting worse. I looked at this site about 6 months ago and someone had the same problem but I forgot what they said it was. It is NOT the alternator or battery because they are new and have been tested. Someone please let me know what this problem is so I can get it repaired ASAP. Thanks!
Other than this, I have had no problems at all and really enjoy my CL.
Hondas and Acuras use what is called a "multi-combo switch." This switch controls your turn signal indicators, headlights and dash lights. when this switch fails, any number of problems can occure. from headlights and signals lamps that fail to turn on, to what you are experiencing. I would suggest that you have this replaced. It is a tricky bit of work, and I would not suggest you try doing it yourself. The procedure for replacing this switch requires the removal of the steering wheel, and airbag mechanism. This can be potentially dangerouse to a novice. Your dealer or a good repair shop that specializes in Acura/Honda should be located and I would imagine the work should not take longer than an hour or two. Good luck.
You can expect the switch to be at least $100 used and maybe $250 new. Not including labor for installation.
Peace, Love and Acura...
Originally Posted by melo72
Mine does the same thing. It started happening after I put in my indiglo guages./ It could just be from where I tapped into though.
mines been doing this for prolly 2 yrs now, i took it to 2 diff acura dealers when i was still under warranty and i figured it was something somewhat expensive and time consuming,
because they always told me they couldnt reproduce the problem. therefore they couldnt fix it if they didnt know what the problem was. but it doesnt do it all the time and it hasn't gotten worse due to not being fixed, so its not that big a deal.
good luck and post the final cost when completed
Originally Posted by phlux77
Thanks for your help. I think I'm gonna get the switch rather than a T-bone. hahaha. I'll let you guys know what I come up with after I replace it.
i have a problem with my MPH and the odo on my car.. they both dont work!!!!! my 97 cl has 125,000 miles on it but i dont know how long ago it broke, i just bought the car a few days ago.... but the engine runs ok, i was thinking of changeing it out with some aftermarket parts but not sure if theres any.... any help would be helpful
In my home town the switch is $50.00 at orileys. Be sure to disconnect the negative and positive battery cables and let the car set of at least 30 minutes before working near the air bag.
mada51589
Jan 9, 2025 04:40 PM
Ny1718
Sep 11, 2015 09:21 AM
