Pic of Shift Rod
Old May 27, 2004 | 07:30 PM
AdamsNew98CL's Avatar
IM RICK JAMES !!!
Pic of Shift Rod
Ok so part 19 is the shift rod, it is what needs to be cut on my car, I figure I need to do about a 4 inch cut, anyone know the total length of this part if youve cut it before how much im working with
Old May 29, 2004 | 10:17 AM
ju5tchi11in's Avatar
roomate has a CL too
pull it out and take a look not to hard to take out I would assume... but I got stick. on the 2.3 looks similar in the "shift linkage??"
Old May 29, 2004 | 11:05 AM
kevin79925's Avatar
i thought this was gonna show some chick shifting a rod into her mouth or something. . hehehe
Old May 29, 2004 | 12:17 PM
jakelovescake's Avatar
Payer of high insurance
why do you need to cut it you have an auto
Old May 29, 2004 | 12:50 PM
IM RICK JAMES !!!
take a look at my www, its merely for aesthetics, i know its not going to improve shifting, im not retarded
Old May 30, 2004 | 02:09 AM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
i did not cut mine and mine sits lower than most auto's
look into the Razo Sport Pump Shifter
not button, just push down on the shifter and put into gear
Old May 30, 2004 | 02:42 AM
nippon_wa's Avatar
nippon_wa 2.0
that's the one that i have..
Old May 30, 2004 | 01:08 PM
ghost_masterCL's Avatar
Well, if you were to cut it at the point where the red lines are, you would have to cut both the inside rod, AND the casing rod that the shift knob screws into. the problems this will cause that you will have to fix are 1.) the inner rod will have to be rethreaded so the angled tip can screw back onto it (BLUE CIRCLE ), and 2.) you will have to redrill, and probably rethread the holes for screwing in the shift knob again (RED CIRCLE)
also, make sure you don't lose that spring at the bottom of the shift rod, that would make it so you would shift into any gear at any time, and that would be BAD.
Be sure to share the results.
Old May 30, 2004 | 01:49 PM
oh yeah, and one more thing... wheree the hell did you get that diagram? I've seen all kinds of diagrams on this site, adn don't know where I could get such helpful information. Somebody fill me in.
Old May 30, 2004 | 02:07 PM
wilp99's Avatar
http://www.acuraautomotiveparts.org/...prddisplay.jsp
2nd best site on the web
Old May 30, 2004 | 03:01 PM
wow, I am now in love with that site... that just saved me $35 for a repair manual... thank you.
Old May 30, 2004 | 03:33 PM
IM RICK JAMES !!!
OK well the screw holes on the outer casing are no longer being used, so that I am not worried about threading. I am wondering if I can do without the angled screw thing on the top and simply just cut the rod. I mean I dont have the tools to do a thread job, so im wondering if it would work without that piece
Old May 30, 2004 | 03:37 PM
IM RICK JAMES !!!
Oh yeah and heres the main parts page with access to all diagrams
http://www.acuraautomotiveparts.org/...catdisplay.jsp
By the way, ghost do you have aim, if so hit me up at adamfoldes
SidhuSaaB
May 30, 2020 12:40 AM
Popee
Dec 20, 2015 12:08 AM
joflewbyu2
Oct 8, 2015 11:16 AM
mellsonnj
Sep 24, 2015 04:42 PM
Hines57
Sep 24, 2015 01:58 PM
