Perfect Shift for stock 2.3 CL
Pass the dutchie!
I found an AEM dyno of the stock f22 engine and i used it to compute the perfect shift point on the 2.2/2.3 and here is a link to the results
http://ganoobies.com/calc_shiftpoints_asp.htm
it says 6250 is perfect
Pass the dutchie!
red99cl2.3: have u ever noticed that if u are driving around and you up shift with out pressing the gas that the car jolts back a little and slows down, but if you shift while the rmps are higher the jolt is less noticable, that is the point to the perfect shift calculator, if figures out where that jolt will be least so your car slows down least and the RMPS stay the highest hoppefully keeping the VTEC engaged
Pass the dutchie!
thats pretty cool acura/honda started the red line exactly where the perfect shift is, thats probably where most people who drag shift at anyway
