Painting Calps
Old Apr 19, 2002 | 03:31 PM
Luckyax2's Avatar
Evolution
Painting Calps
OK I got a ? for you... I bought my caliper paint and have been waiting and waiting for warm weather and FINNALY it is here. How do I go about taking my caliper off? and what else do I need to do besides sanding and using a brake cleaner?
thanks
Old Apr 19, 2002 | 03:40 PM
moforose3.0's Avatar
What can I get ya?
I didnt even take the caliper off when I did mine and it turned out good. It sounds like you have everything you need. I didnt buy the kit, I just went to wal-mart and got some high temp spray paint. I used engine cleaner to clean them. I sprayed the paint on a piece of cardboard and painted it on with a brush. Turned out really well. Good luck
Old Apr 19, 2002 | 03:47 PM
NYKEEROCKA's Avatar
phuck your CL race my F4
if you want to take them off just jack up the car and there should be two blots on the back side of the calp. but make sure you have a c clamp just in case your cylinder comes out a little then you wont be able to get the brakes back on. you should be alright though dont think they should do that.
Old Apr 19, 2002 | 07:23 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
I painted mine several weeks ago, and didn't need to take the calipers off. Just mask off the not-to-be-painted surfaces with newspaper.
Good Luck!
Old Apr 20, 2002 | 11:25 AM
BLACKOUTCL's Avatar
AkA 'Lucky'
most important!!!
make sure the area is clean
the first time i did mine, i didn't clean it real well and the paint looked like crap
so i had to take the whole thing off and wire brush and acetone it, now it looks good
have fun
Old Apr 21, 2002 | 12:05 PM
clxtreme's Avatar
No Too Fast, No Too Slow.
Adding to the ? since I want to do mine......How long did you wait to drive the car again?
Old Apr 21, 2002 | 12:15 PM
Since it took about 30 minutes to do each one (brake cleaner, rinse w/ water, rust reformer, rinse again, drying time, then paint), I would say I drove my car 1 hour after the last caliper was painted (which means it was about 3 hours after I began the project).
Using the brakes helps them cure (due to the high temperature). It's best to wait at least an hour, so that they are dry to the touch (and so that dirt doesn't stick to them), before driving.
Good Luck!
Jul 16, 2017 07:33 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
jmaxima03
Sep 27, 2015 10:22 AM
spoiler900
Sep 23, 2015 04:41 PM
