P0715 code need your help guys
my friend got 1998 3.0 CL and last week his tranny died... we found one on the junkyard for pretty cheap and we swap it over...
today when we first started the car it was running ok but after 10 min CEL showed up P0715(input Turbine/speed sensor malfunction) D4 light blinks.
does tranny oil change may help with anything ? is this tranny gone too or what ? or the sensor is gone bad. please help
6spd FTW
Make sure the sensor wiring has not rotted away and it wouldn't hurt to try a used one. If it's anything like replacing the ones that were on my 2.2 accord, it's one 10MM bolt per sensor and one plug. You can also pull them out and clean them, they probably have a ton of metal shavings on them.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Yep, my guess was to check the sensors, glad you guys got it working
mada51589
05-03-2022 08:54 PM
elietania
4G TL Problems & Fixes
09-05-2015 06:52 AM
