optima batteries
i like orange juice
optima batteries
does anyone know what kind of optima battery we use? i went to auto zone and they dont have one listed but i had them look up a 98 accord 3.0. and since its the same motor, the one for it should work right?
AWD Torque Monster
it has nothin to do with the motor. just the room in your car that you can fit a battery into. just measuer your battery and get one the similar size with same top posts or both top and side posts. you will have to modify the battery tie down rods becuase the optima battery is much shorter. not a big deal. get a yellow or blue top they are the same deep cycle. the blue has extra marine threaded posts which are great for attaching accesories!
-S namyaC-
Red top: cranking only, more cranking amps than Yellow or Blue, also cheapest
Yellow top: deep cyle, can run equipment longer while car is off
Blue top: same thing as Yellow top, but for marine applications - extra set of accessory posts *might be odd size*
Unlike say - a diesel truck, our car doen't need a huge about of cranking amps, so you should be fine with any of them.
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
their blue tops are group 31's I believe.
I have all the info on optimas at work, if you haven't gotten it tomorrow i'll post them up
AWD Torque Monster
red top is not deep cycle but are great starter batteries. my red top had 830cca!!! thats more then the batt in my 5.7 V8 gmc. it started my little 2.2 in a split sec. the yellow and blue are about 700cca. more then we need plus they are deep cycle. i can leave my lights on and flashers for hours when im illegally parked.
Originally posted by d5c5b
ive got a yellow that i drain all the time.......and its great to know i an fully charge it right back up!
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
DOOKS of hazard!!!!
i remember you saying something about you and optima once..........whats the deal? you own it hot shot!? haha, seriously......whats the affiliation?
no, but we own a company that basically headed all deep cycle technology, etc. Created the first electric golf cart, etc.
optima is one of our main competitors. Only difference is we've been around since 1925
I have two yellow tops right now in my 98 3.0 CL. One under the hood and one in the back with an isolator in between. I have no problems charging the two batteries with my 140 amp alternator. I would recommend getting a red top for under the hood. It's a waste of money putting a yellow top in as your starter battery. As a side note, our factory alternator can charge two yellow tops with no problem.
GOT AIR PPPPSSSSSSTTT?
ANY OPTIMA WILL FIT IN OUR CAR. IF YOU JUST WANT IT TO START YOUR CAR THEN GET A RED TOP BUT IF YOU ARE LIKE ME RUNNING 3000 WATTS OF STAREO CRAP AND TO AIR COMPRESSORS FOR MY AIR THEN GO A YELLOW OR A BLUE TOP AND IF YOU ARE RUNNING A LOT OF STUFF THAN YOU SHOULD GET A STRONGER ALTENATOR. WHAT WILL HAPPEN IF YOU ARE RUNNING TO MUCH STUFF IS THE BATTERY WILL DIE FASTER THAN THE ALTENATOR CAN CHARGE IT.
DamnThisHobby'sExpensive!
How much are Yellows or blues?? (my car seems to start fine...but im worried about being able to run my applications for long times with the car off)
I have 2 12" subs with a 500W amp....a 7" motorised TV and DVD and Then Now i'll have HIDS....(plus all the OEM stuff)
Should i be worried about draining the battery? Sometimes i sit and watch DVD's in my car and i turn the car off and i try to remember to start the car back up every 30min to recharge the battery....should i even worry? I was thinkin about gettin a yellow top or blue top so it would last longer while my cars off...
soo how long does it take to drain a reg. battery?? How long does it take to drain a Yellow/Blue top??
http://www.sounddomain.com/sku/OPTSC51RDA
oh yea, $139!?!?! HOLY CRAP!
PS: can we actually use a blue top or is blue tops only for marine equpitment? (arnt blue and yellow the same, just yellow is for auto and blue is for marine?)
i like orange juice
im prolly gonna get a red tommrow...but upgrade later...the only reason why is cause the color wont go with my car.....so ill prolly get a blue in the long run.....
i like orange juice
the reason its only 500 CCA is cause of the reserve....if im not mistaken....but the red will start with no problem....i dont think you need that many CCA..i live in texas so its really not cold hear that often...
anybody seen the battery warmer blankets? i know some come stock..would that help out? to keep the CCA low....
AWD Torque Monster
mine has 650cca u might be lookin at a smaller one. the yellow was also the same. i got the blue becuase
1. it was $30 cheaper for the exact same thing as the yellow
2. it had the 2 extra terminals which i like for accessories
![](http://mywebpages.comcast.net/vx16.temp/blueoptima.jpg)
AWD Torque Monster
Originally posted by truraysa
my blue top says 900 marine cranking amps. and 124 minute reserve capacity. theres also a orange top
and orange top is their standard sealed battery. less cc and cca's then a red top. cost less too.
Originally posted by VXCL
yeah mine is 870 cranking amps. is was talking cca's
i like orange juice
i got my new HU...and the optima today...the deck is way better sounding than the stock bose.....got the deck installed....not the optima yet, had to go to work, where im stuck at right now.....i got a red top for now...the didnt have any blue tops there.....
i like orange juice
stinger is a company that make a ton of stereo products....i think their supposed to be the best you can get.. .. www.stingerelectronics.com think thats the link
Originally posted by tightac1
by the way optima does not make an orange top
MetalGearTypeS
08-29-2016 08:28 PM
