Opinion on CV boot
Old Jul 11, 2008 | 10:17 AM
sporting's Avatar
Opinion on CV boot
Hey guys,
Like most auto enthusiast, I like to take care of my car! I.E. give it a good wash and do regular oil changes and what not... Well today I was thinking I should give my CV boots some fresh grease and give it an armor all coating on the outside to keep it from cracking.
What do you guys think about this? Should I do it or is it a waste of time and money?
I have a 97 CL 3.0 with 82k on it.
The miles aren't there to justify the replacement but the years are definitely there!
Your 's please.
Oh and is it a difficult thing to do?
Old Jul 11, 2008 | 11:33 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
If they're not torn, don't replace them
Old Jul 11, 2008 | 11:46 AM
sporting's Avatar
I am not replacing them but just "refreshing" them with new grease on the insides and armor all 'ing the outside rubber so they won't crack in the future.
Old Jul 11, 2008 | 12:20 PM
(Mid-Atlantic)
ah, yeah go for it
Old Jul 11, 2008 | 01:12 PM
unlewser's Avatar
i think it would be a waste of time to rebuild IMHO. It is so dirty and messy. Also run the risk of putting them back together incorrectly. Just wait til they break, then replace them with a fresh new axle. Mine tore at about 103k
Old Jul 11, 2008 | 01:32 PM
sporting's Avatar
^^ Yes but my point is that I don't want to have to replace the whole thing, rather just do a preventative maintenance than Fixing the problem later on.
Prevent is better than fix.
Old Jul 11, 2008 | 02:11 PM
TexasHonda's Avatar
You could clean the exterior and add protectant. Grease inside sealed boot should be fine. Watch boots as they age and try to catch them before they fail.
regards
Old Jul 11, 2008 | 02:25 PM
sporting's Avatar
^^ So it is not worth it to take the Boot apart and put new grease in there? I would think that the grease would loose it's protection component over time... Doesn't it? If it doesn't then I guess I would just clean the exterior and add some protection to it then.
Old Jul 11, 2008 | 02:28 PM
(Mid-Atlantic)
You're just the first person on here that's wanted to regrease their working axles that's all
Old Jul 11, 2008 | 03:50 PM
sporting's Avatar
^^ That is what happens when you want your car in pristine condition and oh yea, have free time.
Old Jul 11, 2008 | 04:39 PM
SwervinCL's Avatar
Nom Nom Nom Nom
Seems like its more trouble than its worth TBH... When was the last time they were replaced?
Old Jul 12, 2008 | 01:06 AM
sporting's Avatar
^^ Well today after work I went under the car and did a little inspection, the cv boots seem to be in working condition, so I just put on some armor all for the cv boot and brake lines, so now they look real clean and that armor all coat some give it a little better protection from the heat in that area and lube it up so that it won't crack over time.
Old Jul 12, 2008 | 01:36 AM
(Mid-Atlantic)
Yeah? Try painting your condensor You wanna talk pristine?
I painted and replaced my horns and like half my other stock parts
Old Jul 12, 2008 | 11:50 AM
Tehvine's Avatar
6spd FTW
Even when they start to fail you can nurse them til they really go. I used to inject grease in the accord's boots about every week or two and they lasted way longer even with cracked boots.
Old Jul 12, 2008 | 01:13 PM
sporting's Avatar
Looks pretty clean to me 97BlackAckCL.. Question though, why did you choose to paint your condenser? I would think the condenser would be better off with no paint for evaporation?
Just my but good job
dragon084's Avatar
1999 CL3.0
i need some new boots.
mine are shot.
how much is it gonna cost?
Old Jul 12, 2008 | 03:12 PM
Mach30SiR's Avatar
Bagel Bomber
I would't use armor all. The oils can actually cause the rubber to dry and split with prolonged use. Use something that isn't silicone based, or just leave them alone.
Old Jul 12, 2008 | 06:29 PM
sporting's Avatar
^^ Isn't armor all suppose to keep rubber from cracking? From the looks of it, leaving it alone seems to make the rubber more brittle and prone to cracking with prolong use. Next time I'll just use soap and water.
Old Jul 12, 2008 | 07:46 PM
tron's Avatar
I understand your desire to keep your cl in good shape, but theres probably better preventive maintenance you could do. Has your coolant been changed in the last two years? How do your belts look? Is your timing belt overdue? Has your brake fluid ever been replaced? How about your power steering fluid? Im just throwing out some ideas that might be a better use of your time.
Old Jul 12, 2008 | 10:26 PM
(Mid-Atlantic)
I used heat disappating radiator paint
Old Jul 13, 2008 | 02:41 AM
sporting's Avatar
I agree, but yes I have had the following done already:
-coolant has been flushed
-timing belt changed + serpentine belts
-Brakes has been replaced, all 4 + I've gone through 2 sets of 4 tires, now I am on a set of new bridgestone potenza pole positions.
-Transmission fluid gets replaced every 6k
-Engine oil gets replaced every 3k
-ignition kit (spark plugs + spark plug wires + distributor Cap and rotor)
-alignment
-ICON wiper blades
-silver star front lights + led license plate lights
-I have not done the brake fluid or power steering fluid, will soon though.
Old Jul 13, 2008 | 01:49 PM
(Mid-Atlantic)
ICON wipers are great, I still believe armor all isn't a good idea maybe just clean them
Old Jul 13, 2008 | 04:51 PM
TOPHER33884's Avatar
It has been proven before that using armor all on things like your dash/interior/exterior parts etc. cause them to crack more often then not using it, due to the wet coating getting heated by the sun/heat, and actually causing the surface to bake and then crack. Better off using nothing but a damp cloth and/or leather cleaner to keep things looking pristine!
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
jmaxima03
Sep 27, 2015 10:22 AM
