View Poll Results: What to do?
Build F22 and boost
13.64%
Build F22 with H22 head
31.82%
Swap in H22 all motor maybe boost
54.55%
Something else (give ideas)
0%
Voters: 22. You may not vote on this poll
Which one should i do?
Well im keeping the cl but i am stuck on what to do... Basically money isnt a issue i just need some input. I have a couple things i am looking at doing. Heres the options im considering..
-Rebuild my F22 and run 10-12 psi
-Rebuild my F22 and put a H22 head on with some work done to it and run all motor
-Swap in the H22 run all motor maybe boost a little down the road
Like i said money isnt an issue i just want some input on what will be the best. Let me know.
Originally Posted by CL Platano
Eric..what's going on with yours haven't seen any updates?
Originally Posted by ajtcl
H22 is a better motor, for a four banger that is.
How about the J35 block with J32 head.
You could be the next Cocoa.
really hard to swap the V6 into a 4cyl body.
my suggestion would be to just turbo the F22. (depending on mileage)
Well one reason money isnt an issue is that insurance is dumb as hell. It hailed here a week back or so... (golf ball to softball size) My windsheild got cracked and i took it to get a new one and while there they look over the whole car. I have a few really small dents in the pass and driver door that are not noticable unless you are looking down the side of the car next to the paint. from straight out you cant tell.. Long story short i ended up with $2500 for the windshield ($300) and the rest for dents that dont exisit. At least me and my friends cant find for our lifes. So i got $2000 that i am using plus what i have been saving to do this... Anyways the F22 in there now has 217K on it.. so i would have to rebuild it and boost. How much boost could i run on a fully built f22? Theres a J35a or w/e in the blackmarket i was looking at
You could safely run 12psi on a built f22b1. Crunch out the numbers with 12 and see what compressor map matches up best then go from there. Finding a turbo manifold for the f22b engine is probably the toughest part.
There are a few companies that make them, but not very many. The reason for this is that the spacing is 0-00-0 rather than the usual 0-0-0-0. The companies that do make the turbo manifold for the f22b engines usually make the log style ones rather than the more efficient tubular ones.
The best help I can give you is to read this thread very closely :http://www.accordinglydone.com/forum...ead.php?t=6472
Also, the book "Maximum Boost" by Corky Bell is a great tool for learning if you really want to know about turbochargers and whatnot.
save your money, youll need it later. but in the mean time you might as well run the shit out of that engine.
Well still looking into the H22... Searching on h-t I keep seeing mixed reactions to that motor and h series in general.. Not sure what to do yet. Still researching everything, calculating numbers, estimating work, yada yada yada. I still have no clue what to do. The J-series isnt happening.. Looked into it and like ghost said not worth the hassle.
No, definately Pittsburg. I lived in PA for a short while. Pretty in some places, shitty in others. Are you PA guys still allowed to burn trash in barrels around your neighborhoods?
and no, only in the hick areas
first of all college for me is cheap... $8000 for 2 yrs plus about $4k for tools to start with. I want something that is gonna shut ppl up around here. I dont care about getting money back when i sell it. im gonna keep it for a long time yet.
Nah, it's called google images
