NRG hub/quick release install....
Turtle Charged, Biotcch!!
Anyone has experience installing these? I bought them but the instruction is not included in the packaging....
:knock: no one??? 30+ views and nobody can give me any info? i saw at least one CL at the Socal mega meet with after market wheel and QR... who was it? i'm mostly concern with how to install the QR...
Chris/Cocoa?
I got both the slim hub and the QR brand new for a good price, but now i'm not sure how to install them
did you install the hub by yourselves? can you give me some pointers?
thanks
thanks
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by AznX TL
the only person that i can think of that has it is shavedh22cl
blah blah blah
There's instructions over at the v6 forum. Here's a quick one for you. But make sure you look it up. Cause i might have left parts out that i don't remember.
Make sure your steering wheel is centers and straight
You'll need to unplug the negative battery terminal. let it sit for a few mintures first.
then unplug the airbag from the bottom of the steering wheel.
use a hex screw bit to remove the two screws on the side of the airbags. Now you could remove the airbag.
Using a breaker bar, remove that center bolt holding the steering down.
To remove the steering wheel you could either start pulling it toward you or go rent a steering wheel puller.
Once its removed, there's the srs controller (black thing with a ribbon cable, i think) I think there's either 3 or 4 screws holding that down. Remove that controller.
Now just install the hub, quick release and new steering wheel on.
If you want to run the horn, you'll need to tap into one of the wires on this harness that has three wires. And run it to your new hub. I believe its the green/blue one but that's just from the top of my head. I'm not too sure. You'll need to look up the wiring diagram for that. I don't have it with me right now.
2600lb CL
Originally Posted by legion653
its a bad idea to replace the steering wheel, especially if you get into an accident and it could've saved your life =/
WEAR YOUR SEAT BELT!
Airbags come out at speeds over 250mph. If you're too fucking close to the steering wheel cause you're a midget, it can kill you, or cause serious injury. I believe if under a certain height, you can take your airbags off legally by a professional. My ex's mom was like 4'6" and had hers taken off legally.
B A N N E D
Originally Posted by Cocoa
It saves the lives of the dumb shits that dont wear seat belts. I've had the airbag come out like 4 times throughout my life. It just burns the shit out of you. Seat belts saves lives. Airbags, well, they arent gonna save you at low speeds unless you're not wearing a seat belt. And at high speeds, well you're fucked anyways without a seat belt.
I dont want to make a new thread so i'm revisiting this one...
Anyone knows how to wire the horn button? I got the shoe horn but i think there's something missing because i can't seem to get the horn to work...
Who has momo wheels and working horn button? please help...
Thanks!
Thanks!
blah blah blah
To get the horn to work, you just need to tap into one wire and just run a ground wire. Like I have mentioned above, the wire is blue with the green line on it. But not i'm 100% since I'm in Chicago right now and ride is back in CA.
sold!
Originally Posted by Sleep_DEPRIVED_Sleeper
cool, thanks. I'll try it again this weekend...
just the ghetto alarm chirp
blah blah blah
One more then. For the ground, you don't really need to run a wire. I just use a piece of metal and mounted on one of the screws on the column. The metal piece touches the part on the steering wheel that's for a ground.
Originally Posted by CLpwner
holy shit... you have to be going 250 for the airbags to come out... why even have them... i never have been that fast in a car...
he meant the speed of the airbag explodes towards you, not the speed of the car you are in...
but i get what you are saying now... me
(Mid-Atlantic)
(Mid-Atlantic)
2600lb CL
wow... big misunderstanding... I was being sarcastic cuz i thought he meant 25 mph ... so if you are going 25mph the airbag will come out if u get in a wreck...
(Mid-Atlantic)
(Mid-Atlantic)
The front airbags still come out around 200 MPH which is an industry standard, the curtain air bags come out slower I believe because they drop down. And it all depends on the car as to when they go off, they rely on crush zones to trigger the chemical reaction that deploys the bags, and that only happens when the frame or specific impact zones in the front are affected.
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
