Is this normal ???
Is this normal ???
Everytime i start my CL i hear a buzzing sound for about 5 seconds . The noise is similar to how an automatic car antenna sounds while retracting . I took it to a dealer and the guy told me its normal . The computer that checks my ABS system makes noise while preforming its task ,he assured me that its a normal and a common problem with most CLs .----- I was just wondering if anyone else out here has the same problem ????
Its your ABS pump.Its actually more of a MMMMOOOOOOooooooooooo sound. Pray to the brake gods that your abs module doesnt go out, because its $1000 for a new one. That seems to be a common problem with hondas.
There is a very good chance that you might suffer from the same problem a lot of cl owners have faced: bad ABS module. something in it goes bad and causes the pump(which is the mooing cow sound heard when the car starts up) to overrun. Once this happens, the system disables until you restart the car and the ABS light will illuminate.
Thats really funny actually cause tonight I was pulling into my friends neighborhood and Im just sitting there waiting for him to come outside and my car was like MOOOOOOOOOOOOOOOOOOOOOOOOOOO. My friends were like wat the fuck im like it always does that its always random.
ABS MMMMMMOOOO sound in-behind steering column
Originally Posted by tek01
Hi, so other than replacing the ABS module, I have read on another post that you may try and change the batery or verify the pos adn neg connections are not oxidizing. I got my mechanic to run the error code because my ABS light is always on. mechanic said after checking the resistance in the rear abs sensor he said it was a short in the driver side rear abs sensor. Some people on the board have replaced up to 3 of these sensor and they still have the probleme, is there a more complete post about this issue or a post that discribes this probleme in its entirety?
The thread about the module o-rings:
http://www.honda-tech.com/zerothread?id=205285
Since you searched this thread, and asked for a detailed write-up I put that in there for ya, however your issue sounds like it's just a WSS so I would start by replacing that before you worry about other issues in your braking system. Hope all the info helps
abs module mmmmmooooouuu
97BlackAckCL thanks for the quick reply, it's kind of funny because I spoke to my mechanic about what you had been through. A few months ago we ran the codes and found that a driver side rear abs sensor cost approximately 300$, Yeah. So I didn’t replace it and here we are now. I think I will clean my battery terminals and then install a new battery. If that doesn’t work I will hunt down that rear sensor! . ps thanks for the fast reply!
Wheel speed sensor!!!
You can get the wheel speed sensors for a CL/Accord on ebay for $50-60 US usually
No chit! damn i never thought looking there i will do it later tonight! Thanks buddy.
I have been on eBay with no luck of finding any specific cl wheel speed sensor. Perhaps I should be looking for a the 94-97 Accord (F22) or a 98-2002 Accord (F23) wheel speed sensor. Or should I call Honda and see if the part number matches up the same against the above mentioned cars. What do you believe my best option is?
Hi Acuraziners im back!
My ABS light is still on and I really want to solve the probleme. I decided to change the battery and got my mechanic to reset the abs light. it came right back on as I stared rolling.
Does anybody know the part number for the rear abs sensors. - for an acura cl 2.2 97 automatic.
Thanks for your post.
Damn, don't know why but that was funny as hell.
Just to let people know im goin to be installing these as soon as i find new ones, as all the ones on ebay seem to be used, we will see what happens!
94-97 L/H REAR WHEEL SPEED SENSOR
Genuine Honda replacement part. Fits models with ABS only.
Part #2857475
94-97 R/H REAR WHEEL SPEED SENSOR
Part #2857470
Part #2857475
Part #2857470
how hard is it to replace the wheel speed sensors and how much do they cost? since i've had my car my speedo says im going 65 when i know i cant be going over 50 (this was before i took the stock wheels off), plus my abs light has always came on
Your speedometer has nothing to do with your wheel speed sensors, those are for your abs, the Vehicle Speed Sensor in the transmission controls your speedometer
MrHeeltoe
20
Feb 23, 2023 01:54 PM
rockyboy
Oct 2, 2015 10:45 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
