New headlights + question + help
Old 06-11-2004 | 12:28 AM
CL22's Avatar
Hey guys,
just got my new headlights in the mail today. Put em in, and tested them out. I bought a pair of high beams and low beams 7000k. They're HILITE Superwhite XE bulbs. Well, the light output is not as bright as I hoped for, when I'm driving. But when you look at it from outside, it seems pretty bright.
Now, for the problem/question: The left high beam bulb *blew* in the housing as I was taking pics of it, so I had it running for about 10 mins. I made sure that I did not touch the bulbs when installing them, so I'm not sure what made it blow. Also, I touched the outside of the headlight, and it seemed pretty hot. I dont think I've ever touched it to see how hot it gets when stock. Anyone know?
Anyway, my real main question is: How do I get the shattered glass pieces out from the high beam housing?
I took some pics of the superwhite lights. I also have stock..check em out.
Stock front:
Superwhite front:
Stock side:
Superwhite side:
Old 06-11-2004 | 12:30 AM
CL22's Avatar
Superwhite high beams:
Superwhite high beams side:
Also, how would I go about adjusting the angle of the low beams? I'd like to point them up just a tad bit, so I can see a little further ahead.
Thanks guys!
Old 06-11-2004 | 12:40 AM
xrunner86x's Avatar
A-CL Totaled Member
Adjustment is covered in the manual, but if you look at the top of the light you will see a little level and a place to adjust the height by using a philips head screwdriver.
What was the bulb wattage? A lot of aftermarket bulbs are really too high to run off stock wiring and sockets. I melted a bulb that was over the stock wattage, but I've never had one blow. To get the glass out, either you need to take the headlight out and shake and/or open it up, or find some tiny-ass vacuum attachment.
Old 06-11-2004 | 12:44 AM
DanMan1464's Avatar
Autobot
....it literally blew up? what the hell?
I think you have to take it apart....
Also they are FAKE HID's, just the color, so the output won't be very good...about the same as stock.
You need a real HID kit or a Projector swap to have nice output
Old 06-11-2004 | 12:54 AM
99CL's Avatar
blah blah blah
I think you'll have to take the headlight apart, or try shaking it out.....
sorry for being off topic...but dan, i finally got my car back and washed it. The headlights fog up when u said they wouldn't....just wanted to let u know, now i have to fix it...
Old 06-11-2004 | 12:57 AM
CL22's Avatar
The wattage on the bulb is standard 55W for the 9006, and also the standard wattage for the 9005. I emailed the seller to see about getting replacements, but I really need to get the glass pieces out, and I don't want to have to take apart the housing. I guess I'll have to try and find some tiny vacuum attachments.
Old 06-11-2004 | 01:07 AM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
you probably touched the lense of the bulbs and thats how it blew up man
the only way to get the pieces out is to take off the headlights and try to dump out the pieces
you do this by taking off the bumper and taking off the headlights, there are 5 10mm botls holding in the lights
do a search for instructions on how to do this, it has been discussed on here many of times before
Old 06-11-2004 | 01:08 AM
this had happened to a spare headlight i had that i sold to a member on here and all i did was take the light and tip it so that the pieces go towards the hole and then use some needle nose plyers and take the pieces out, also shaking the headlamp will also get the pieces out
Old 06-11-2004 | 01:30 AM
DIO 87 Prelude's Avatar
CL Poser AKA Tool
And this is why you dont buy rice headlights.
Sylvania Halogens light up the night just fine and 90% better than blue painted bulbs.
Old 06-11-2004 | 01:58 AM
CL22's Avatar
Yea...should have stuck with the good shit. Oh well...live and learn I guess. But damn, I gotta take out the bumper to take off the headlight???
Old 06-11-2004 | 02:18 AM
klepto's Avatar
pretty much yea, if you have someone else to help you, its not that bad
Old 06-13-2004 | 02:00 AM
CL22's Avatar
I think I have an idea. What if, I took a skinny stick or something like that..and put tape at the end of it, and just picked up the glass peices with the sticky side of the tape??? DAMN, I'm a genius!! How do i sleep with all this genius-ness?? :P
Old 06-13-2004 | 02:04 AM
DanMan1464's Avatar
Autobot
hhahahahaha
Old 06-13-2004 | 02:11 AM
infamouz trunkz's Avatar
have fun picking up the pieces
Old 06-13-2004 | 02:32 AM
CL22's Avatar
There's not a lot of pieces...maybe just sevel hundred. Nah, j/p..i think theres only a few pieces..so it shouldn't be that bad at all.
tman570
06-11-2019 08:56 AM
BoricuaTL
04-08-2016 02:08 PM
eastcoastguy
09-24-2015 03:07 PM
datadr
09-12-2015 10:12 PM
prox
5G TLX Problems & Fixes
09-01-2015 03:03 AM
