Neuspeed Spring owners check in here...
Old May 7, 2004 | 12:22 PM
EPS CL's Avatar
SSM Accord V6 6 Spd
I'm pretty set on getting a Neuspeed drop, but I would like to see some pics if possible. Did you need a camber kit, new shocks, both?
Let me know, so I have an idea as to what I need to buy...or not buy cause I'm so damn cheap.
Old May 7, 2004 | 02:54 PM
Cocoa's Avatar
2600lb CL
camber kit, it'd save you money on having to get new tires all the time...it goes for about 50 bucks...
Old May 7, 2004 | 02:59 PM
18anatak's Avatar
I used to have neuspeeds, i'd recommend getting the camber kit.
Old May 7, 2004 | 03:09 PM
Randol's Avatar
Do a neuspeed search on the forum you should find alot of info with pictures included. Nuespeed does appear to be a nice drop but anything lower than 1.5 on almost any car will need a camber kit. If the car is older than five years and you are going to use lowering springs I would change the struts also because whatever life they have left will disappear very quickly when you lower the car. This will all add up. There is no cheap way to do a quality drop.
Old May 7, 2004 | 03:15 PM
rad_cl_racer's Avatar
Fawkin Gruvin
i have nuspeeds and you saw my ride and i think that its about a 2inch drop, I think that I definitly need camber kit!!
how much do they go for ?
i found a kit for the front that went for $$133.
just a camber kit
doesnt that sound a bit steep for a camber kit?? where can i find a cheeper one ???
Old May 7, 2004 | 03:43 PM
EPS CL's Avatar
SSM Accord V6 6 Spd
hell yea dude, im down for a cheap (albeit good) camber kit.
i went by tybrid performance here in austin the other day. they wanted 200 to install everything. the guy said that camber kit would be free to install, but they charge 250 for the neuspeed springs and 185 for the camber kit. they also said i can bring my own stuff, so ill save big on that.
i know i can get the neuspeed sports for 145 shipped, but what is a decent camber kit and how much do they go for?
Old May 7, 2004 | 08:39 PM
xxx's Avatar
xxx
I've got pics on page 2 of my W W W. Eibach vs neuspeed sport. I needed camber kits front and rear. I'm in Canada, my camber kit was $140.00 cdn for front and $170.00 cdn rear.
DO IT RIGHT THE FIRST TIME!!!! Dude take the advice or you'll end up spending more in the long run. I had enough for so many mods: air ride lambo doors but it all went to suspension and tires.
Old May 7, 2004 | 08:44 PM
Minch00's Avatar
Pit Stop?
Yes, the Neuspeed drop requires a camber kit! You'll eat through tires in just a few months if you don't have one, trust me, I know!
Old May 7, 2004 | 08:52 PM
98AcuraCLpimp's Avatar
ha sanyone installed a camber kit themselves?
xxx's Avatar
xxx
Old May 7, 2004 | 09:30 PM
97Cl22's Avatar
Comrade Stalin
Yes camber, and good choice cause the drop looks great. Take a look at my WWW for pics.
Old May 9, 2004 | 02:00 AM
layedout95's Avatar
The CL has the Neuspeed's on stock struts with no camber kit. No major tire wear as long as you rotate your tires. I seen a bad ass Camber kit for the Cl that was like $300 it was adjustable, it also came powder coated, will end up getting it when the air ride is installed to reduce negative camber when the car is air out.
Old May 9, 2004 | 12:49 PM
EPS CL's Avatar
SSM Accord V6 6 Spd
Cool, so does anybody have an suggestions on a good camber kit?
Do we get the 94-97 accord application, 4 or 6 cylinder?
Old May 9, 2004 | 01:15 PM
xxx's Avatar
xxx
Check out this site http://www.ingallseng.com/cars/acura.html
Old May 10, 2004 | 10:58 AM
roddymerritt's Avatar
RODDYS
I got Neuspeed springs and just left my factories on there for now until I get the money to get new struts. Mine at first slammed my car, then I got 18's and it didn't looked so slammed but after riding a while the ride highth is good except on the driverside front I think my strut has went out.
Old May 10, 2004 | 11:00 AM
RODDYS
I would say get a camber kit because that way you don't have to worry about rubbin your tire and tokico makes a nice one
Old May 10, 2004 | 11:16 AM
d5c5b's Avatar
DOOKS of hazard!!!!
yes, ive installed my camber kit myself...along with my springs and struts.....installed it all myself...progressive and ingalls are a good co to look at for camber kits....expect to pay about 150 ave. for a good kit...and thats just the front...you wont need rear....besides...there is no "camber adj" for the rear...theres only adjustable lower controll arms...but i promise....you wont need a kit in the rear....check my www for pics of my setup... muespeeds sports/kyb agx/ progressive front camber kit......... oh, and do it all at once...otherwise youre wasting money and time
Old May 10, 2004 | 07:16 PM
nippon_wa's Avatar
nippon_wa 2.0
Re: Neuspeed Spring owners check in here...
yep... u can see my www..
i have neuspeed springs w/ progressive camber kits...
front 2.2" and rear 2.0"
i've had them for around 2 years, and didn't have to change the shocks..(still stock and no problem)
like everyone says, it's better for you to have camber kits..
Feb 25, 2020 09:57 AM
Zonian22
Nov 14, 2015 01:20 PM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
PortlandRL
Sep 14, 2015 12:01 PM
DUECE_DXJ
Sep 7, 2015 06:40 AM
