Need some help before tomarrow!!!
Alright tomarrow I am going home and installing my amp to power my new Polk Momo MMC690 6x9's. The amp I am installing is a Rockford Punch 500S and I was planning running the bass link up to the center console so I will have to remove the driver seat. Someone said there was 4 bolts under the chair and I would assume a harness for the power seats, that task dosent sound to hard am i wrong? Second I was looking along the door sill and I dont see any screws so how do I remove the doorsill so that I can peel up the carpet a little to run the power lines to the trunk and does this involve removing the the back seat?
the door sill just pops right out dont be shy and snatch that biotch. i dont see why you woudl need to remove the seat but i guess it woudl be a cleaner install. just be careful when you unscrew the four screws and start to remove the seat not to pull toooo hard or you;ll snap the harness, just pull it back a bit and unhook the plugs
04accordcpe
24
Mar 30, 2008 08:55 AM
