need some help
Old Oct 8, 2008 | 09:52 AM
young03's Avatar
its JDM yo!!!!!!!!
Question need some help
question bout my 97 acura 3.0cl tranny when im on a slight hill my car drifts back a little bit but wen im on level ground or going down a hill im fine do u think that it could be a fluid problem????thats wat im thinkin it is any help would be greatly appreciated thanks guys
Old Oct 8, 2008 | 09:56 AM
artbran's Avatar
666 Speed
Check your fluid if you want, however this sounds normal to me...
Old Oct 8, 2008 | 03:16 PM
young03's Avatar
its JDM yo!!!!!!!!
my fluid seems ok but then again i dont know which dot shows that it is full.. but neways it shifts ok once in gear thats why im wondering if it is low or something
Old Oct 8, 2008 | 03:20 PM
MoSp33d's Avatar
N00berator
on the dip stick there are two holes and the sec. hole make sure the fluid is passed the sec hole. Also the color should be pink....and smells like actual fluid and not burnt toast.
Old Oct 8, 2008 | 03:22 PM
MoSp33d's Avatar
N00berator
o btw, u HAVE to check ur fluid on a leveled road. not on a hill. it alwyas gona be low when on a hill...so check it on a levelled road
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Gravity is gonna make your car drift on a hill, as for fluid, should be filled to the second hole on the stick, not much above that, you can overfill the tranny
Old Oct 8, 2008 | 03:35 PM
young03's Avatar
its JDM yo!!!!!!!!
imma check in a lil bit thanks fellas
