Need Instructions on Installing Gauges!
Does anyone have instructions on how to install the indiglo gauges for 97 cl. I know there was a posting a while ago with detatailed instructions. If anyone knows where that is or if anyone has instructions for me it would be really helpful. Thanks
search for it, but if you cant find it i can give you a quick run down of what you have to do. First you have to to take out your cruise control and dimmer switch, behind them are 2 screws. Then take out the two screws at the top of the black guage cluster. take that off then i think theyre are 4 more screws behind that, 2 on top, 2 on bottom. Take the actual guage cluster out after that and unplug the three wiring harnesses. Then CAREFULLY slip your new guages over your old ones. do it SLOWLY and CAREFULLY or else you WILL break off your needles..then you have to tap into the ground and power wires from the dimmer switch and then put everything back together...sorry dont really know much about the wiring...maybe you'll find the intructions or someone else will tell ya...hope this helps
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
