need help wiring the h22a!
can anyone tell me what they did specifically when they wired up their dizzy? like what wiring to match up and everything. I know that one of the pages tell me that I can use our cl harness but its jus not working out.
Ok from the view of your connector, my pins are all the same on that side. On the harness coming from the dizzy side,
Black wire connects to grey wire
Red wire connects to white/blue
white connects to white
black/ yellow connects to black/yellow
yellow connects to pink
green connects to white/blue
blue connects to blue
yellow green connects to white/green
Let me know if that makes sense. If not I'll go take some pics for you. I hope that helps!
Distributor
Connector from distributor side
The wiring harness connector side is the same as the pic you posted. Also, I'm running an OBD2 to OBD1 jumper harness to a P28, not the CL ecu. A P13 also failed to even turn over my H swap for some reason, but the P28 from phearable.net worked like a charm.
Acura604
20
Aug 5, 2017 12:55 AM
SUPRMN84
Oct 7, 2015 09:46 PM
