need help tranny plug
i have been searching for a min now and can't find anything about the the tranny plug location. I am going to install a tranny cooler per DIY but i want to change the fluid first. i put it up on the ramp today and took a look and there is a lot of bolts down there. how can i tell which one it is? thank you for your help!
Originally Posted by vocabsr
wow thanks, but what number is the drain plug for a 3.0? im not seeing it. thanks
it looks like it got cut off in the picture, ^^^ but judging from the other pictures i would say its the bolt w/ the #11 washer.... good luck w/ the tranny cooler install
It's the only plug on the bottom of the transmission housing, you can't miss it, the tranny is a big silver housing, with 2 pieces sealed together with gasket sealer, and there is a drain plug almost directly below the top fill plug
ITSJESTER
17
Dec 6, 2018 02:29 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
