need help with torque specs from helms manual
ok... i need the torque specs for:
motor mounts.
tranny housing.
pressure plate (where it bolts on to the flywheel).
water pump.
head studs (the ones that go into the block and hold the header on)
i guess thats it. im changing the clutch/fly assembly, timing belt, balancer belt, and water pump.
help.
motor mounts.
tranny housing.
water pump.
help.
Passenger side mount 47lbft
Tranny mount 47lbft
Rear mount 47lbft
Front mount 47lbft
Tranny housing-assuming you mean the bolts holding tranny to the engine and not holding the tranny together..... 47lbft for all 5
Pressure plate 19lbft
Water pump 8.7lbft
Header nuts 23lbft
Timing belt tensioner 33lbft
I'll send you tha bill for the info.
BTW, you ought to have one of these manuals.....
Tranny mount 47lbft
Rear mount 47lbft
Front mount 47lbft
Water pump 8.7lbft
Header nuts 23lbft
jamestheunderdog
Jul 19, 2016 07:58 PM
Sep 17, 2015 09:01 PM
