need help install aem cai
Old Oct 18, 2002 | 05:09 PM
Frogman's Avatar
i am in the middle of installing a cia and not sure what to do now the lower half of the stock intake tube has several tubes and wires going to it what do i do with them
Old Oct 18, 2002 | 05:20 PM
Yajarobi420's Avatar
what kind of wiring. all the black plastic stuff thats connected to your intake take it all out so, there will be a big hole for your intake to go through.
Old Oct 18, 2002 | 05:29 PM
Frogman's Avatar
i am talking about some sort of hoses and an actual electric wire that goes in to something that is attached to the arm coming off the main peice of the stock intake
Old Oct 18, 2002 | 05:38 PM
are you talking about the hoses near the throttle body, but on the intake?
Old Oct 18, 2002 | 06:01 PM
VXCL's Avatar
AWD Torque Monster
rip all that shit out. as u will find out all that crap goes back to one vaccum line up by the firewall that needs to be capped. as for the electrical connector. undo it. that is the A.I.R. system and isnt needed. RIP IT ALL OUT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!! and then ur car will look like this.
oh yeah u dont have to disconnect the coolant line from ur throttle body. u can just use the stock pieces which include the hose going from the top of ur valve cover ( the 2.2 VTEC cover)
to ur intake for ur new intake. ill prob switch back to that only cuz it looks neater. wish i didnt waste my time changin that. its completely unecessary and u will spill engine coolant all over the place.
Old Oct 18, 2002 | 07:07 PM
Frogman's Avatar
so i don't have to mess with the colant thing at all
Old Oct 19, 2002 | 01:32 AM
MaCe's Avatar
fellow MASShole
just take all the black clunky peices out .. theres a wire or 2 that dont connect to anythin .. if i remeber correctly
Old Oct 19, 2002 | 10:23 PM
Frogman's Avatar
ok now i have it in right i think but i have an extra peice or two one is an extra hose and another is an extra foam peice are these ok extra peices
Old Oct 20, 2002 | 06:36 PM
VXCL's Avatar
AWD Torque Monster
yes u dotn use the foam and u should have one xtra hose if u didn;t replace the coolant line on the throttle body. ur done!!!!!!!!!!!!!!!!! just reset ur ecu and enjoy. u can do it by pulling the fuse or disconnecting ur batt for a while. then just start up the car and let it warm up normally
Old Oct 20, 2002 | 11:13 PM
Frogman's Avatar
thanks
i have a problem now with a stuter around 90 miles an hour i am guessing resting the ecu will solve this if not please help i did intsll the bypass valve too
Old Oct 21, 2002 | 11:27 AM
VXCL's Avatar
AWD Torque Monster
thats ur prob. you dotn need that crap. unless u drivie trough 1ft deep lakes and puddles its all nonsense. i havent had a prob in 3 years and i drive in bad t-storms all the time and on the highway. unless ur a moron or ur car is slammed on the ground u dont need it.
Old Oct 21, 2002 | 11:41 AM
Frogman's Avatar
I have a friend that has a integra type R yes it is a real one and he sucked water into his engine so i just wanted to be careful. So you are saying my bypss valve is opening causeing it to stuter
Old Oct 21, 2002 | 06:58 PM
VXCL's Avatar
AWD Torque Monster
dont know if that is it exaclty im just against the bypass. AEM scared so many ppl into buying them that it pisses me off. especially at $30 a pop. did ur friend tell u how he managed to suck up water? theres really no way for water to get to the cai if everythign is right unless u submerge it. anyways if i was u go to a auto parts store and just get a rubber hose connector like the one supplied by aem on ur throttle body and slip that on in place of ur bypass. aslo where did u put the bypass? there is a certain spot. i think its no more than 1ft from the end or somethin like that.
Old Oct 21, 2002 | 07:09 PM
i took off all my wheel wells in front and i drove in pretty heavy rain with my aem cai with no bypass and nothing went wrong.
BoricuaTL
Apr 8, 2016 01:08 PM
InFaMouSLink
Oct 27, 2015 06:51 PM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
TxRzrBk
Sep 17, 2015 01:07 PM
Abe_Froman
Sep 16, 2015 01:27 PM
