need a fuse...what kind?
2.4 L iVtec
my 194 corner light is out (the one for the headlamps) and it isnt the bulb cause I tried like 4 other bulbs and they didnt work either. Where would I get a fuse for it? I pulled off what was the fuse (i think) and it said stanley 9306...?
2.4 L iVtec
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Just one light is out? That's not a fuse sounds like the wire is cut or the socket is bad
Bagel Bomber
i agree its not a fuse.
Matt
Originally Posted by Mach30SiR
I have the same problem interminantly on my drivers side one. If i tap the headlight just right it will come one. I;ve already played with the connections so its not that. It really hasn't bothered me enough to replace the socket and soder that up so.....
Look at the fuse that you took out...if the wire portion that you can see is still in one piece then its not the fuse. If, however, there is a break in the wire then the fuse is bad. I'd check for corrosion in the socket...it happened to me on one of my taillights...a trip to the junkyard solved that problem.
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by jumpmanbsktbll
the socket comes off so I think its the socket
its only on my passenger headlight, corner light is out and i tried ohter bulbs but they didnt work either
One custom CL
sometimes its not the fuse. when i blackhoused this kids lights that somewhere in here they werent working. we checked all fuses and i came to the conclusion that something had burnt out and it wasnt the fuse
Eggs999bacon
09-24-2015 10:08 AM
