Is this my clutch
Is this my clutch
My car i thought had a decent feeling clutch never slipped or anything like that. Its a 97 2.2 5spd, then the other day i got in my car and suddednly the clutch pedal was all slack and i could barley get the clutch disengaged enough to shift. Then the other day i couldn't push the clutch in at all so i can't get the car to get into gear so its just sitting outside in the parkinglot. Is this my clutch or something more serious?
when you said that you couldnt push the clutch in at all do you mean that the pedal would not push in? or do you mean that you can push the pedal all the way down and your clutch does not work. If you can push the pedal all the way down and you try and shift and it grinds and will not let you put it in gear then you need a new clutch.
One more quick question i talked to the repair guy and he said if my clutch wasn't slipping it could be a hydrualic leak. I looked at the resuvaior and there was a little pool of fluid at the bottom of it but its really shallow not sure if it should be filled to the top or what. Any help would be great.
SidhuSaaB
05-30-2020 12:40 AM
