My CL keeps cutting off
Old Nov 7, 2006 | 01:36 PM
Ellicit's Avatar
Let's say I drove the car for almost 3+ hrs and I turn it off. When restart it back up the car acts funny... like its about to shut off on me the engine shakes and then when I press the gas hard it gets normal... the other night I was driving home doing about 60 on the express way the car shut off on me and the green key sign came on the dash broad. I pulled over and started it back up... happen about 3-4 time
What could it be?
Old Nov 7, 2006 | 02:41 PM
AznX TL's Avatar
where is....
theres a recall for the ignition switch on some first gen cl's, just call your dealership with your vin in hand and see if the recall apply's to you.
Old Nov 7, 2006 | 03:43 PM
5-speed's Avatar
4x4- fat chicks cant jump
sounds like ignition switch. i believe the green key means the immobilizer is activated, so it pretty doesnt recognize that the key is in there. thats my guess. like aznx said, call your dealer.
Old Nov 7, 2006 | 05:20 PM
AznX TL's Avatar
where is....
try pushing your key up while in the ignition, ussually if that helps its the ignition switch
Old Nov 16, 2006 | 01:54 PM
Ellicit's Avatar
I think its the ignition too... can you please explain what you mean by "pushing your key up"
thanks
Old Nov 16, 2006 | 02:21 PM
Ellicit's Avatar
can loged into the Acura Owner link and it said they already replaced it...
but I'm going to still call to see if it need to be replaced again
Old Nov 16, 2006 | 07:32 PM
AznX TL's Avatar
where is....
i mean while you're driving, pushing up the key while its in the ignition
Old Oct 17, 2007 | 11:55 AM
Ellicit's Avatar
I check with the dealer and they replaced the ignition switch
I dont have an OEM key, I mean I dont have ACURA written on the key!
Can it be an ideal sensor
Old Oct 17, 2007 | 12:00 PM
AznX TL's Avatar
where is....
no, if it were the sensor it would just not turn on.
Old Oct 17, 2007 | 12:01 PM
AznX TL's Avatar
where is....
what yr and engine is it?
Old Oct 17, 2007 | 12:06 PM
Ellicit's Avatar
its a 1998 and 3.0
Old Oct 17, 2007 | 03:30 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Could be idle sensor or throttle position sensor
Old Oct 17, 2007 | 03:47 PM
AznX TL's Avatar
where is....
i'd check for a bad ground.
mlody
Dec 4, 2019 02:11 PM
DerrickW
Nov 15, 2015 05:52 PM
Timmy18
Oct 17, 2015 03:58 PM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
polish_pat
Sep 25, 2015 12:24 PM
