is my car suposed to idle at 400rpm?
If the car is warm when it's doing that, i dont believe theres anything to worry about. Mine used to idle really low too but functioned fine.
Just got a 97 2.2CL and it tends to idle around 500rpm which is totally smooth, however the A/C causes it to drop a bit and then I feel some shaking....any way I can fix that?? I guess ideal idle RPM would be around 700, then drop to 500 with A/C?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Mine idles around 500, could be your throttle position sensor
me likes whats i's sees
i idle at like 1000 without ac and 800 with i know its high but it used to idle real low and felt like it was going to stall so i turned it up
Originally Posted by southernjerseycl
is yours an automatic? mine's a stick and it idles around 500-600, its perfectly normal.
I'm gonna be doing a timing belt service soon, will adjust idle after that's all done...
Ballin' on a budget
Originally Posted by DoubleSh0t
WTF?
anyway, this is of interest to me, I had a pretty rocking idle shake. It hasn't happened since I filled up once with premium... could have been something else...
Originally Posted by johnnyblaz3
same thing happends but i dont use a/c.. only happends when i turn the wheel all the way to the left or right... also some other times to but i cant remember.. im pretty sure theres no way to fix it? or worth fixing
i have a 97 2.2 cl and have the same problems. Just so you know their is a pressure sensor in the ps line that is suppose to relay a signal to the ecu when their is a high ps load so it can raise the idle to compensate.
Their is also a similar setup with the ac system. I haven't checked mine out yet but I'll let you know when I get around too it. For the time being you can just raise the idle at the throttlebody with the scew by turning it toward the firewall, this doesn't fix the real problem though.
My car idles at around 6000 rpm.
As soon as i let go of the clutch.. i do burnouts, and the only way to stop the car is putting it in neutral and brake. Do i have a problem?!
lol, seriously.
My idle is arround 700 but i allways varies, goes from 700 to 500, it shudders a bit then goes back to 700.
Its wierd.
My integra, the iddle is really low also..
lol, seriously.
Its wierd.
My car shakes when it gets below 600rpm in drive
It idles between 800-900RPM in drive, and between 1000-1500RPM when in park (depending on if the engine is cold or hot)
Mike Bertram
09-10-2015 09:27 AM
