My car chirps n squeaks like a bird!!
Well if my hood squeek wasnt bad enough a new squeak intruduced its self to me this morning... It sounds like break squeaking but I only hear it when i move very slowly. I know its not the breaks because it makes this noise when im not touching the break pedal. I have no idea what it is.... Squeaky wheels?
also my hood squeaks when it rattles? i go over little bumps then my hood chirps.. it gets really bad on rough roads. any tips on getting rid of that?(i did greased up the hinges and nothing changed)
Originally Posted by WineRed2.2CL
your upper control arm is bad. Take the wheel off and check it to see if the rubber seal is cracked.
but what is an upper control arm?
no i dont think its a control arm. i had the same thing, and it was the warning tab on the break pads telling you to change them. But u have more then half of the pad left, just drive it til it stops, or you can take off the wheel and bend the tab back and it will stop
Originally Posted by Nautsiju
The tabs make noise even when your not on the brakes? because i dont hear the noise when i break. only when im idling in drive.
well some times i squeek when breaking.. but i knew that was breaks. ill get new break pads and find out eh?
check your brake pads
the front of my hood also squeeks when ever i go over little bumps. i sprayed the air springs what ever there called that didnt help. im about to spray the point where the hood locks back into the car. though i dont know if that would be bad?
i kno my shit used 2 squeak because the guy b4 me put H&R lowering springs w/ stock shocks... bad idea... cause it wore my shocks out twice as fast... but seeing that you still have stock suspension... it could be bushings or ur upper/lower control arms like said b4... either way good luck...
ya im gettin those as soon as i find some for a nice price.
http://cgi.ebay.com/ebaymotors/Energ...QQcmdZViewItem
Can't find a better price than that for the whole kit
My local Autozone carries the Hyper Flex kit for 2 or 3 dollars higher than eBay (i bought the kit already, wasn't looking for it at Autozone but just saw it out of the corner of my eyes), you won't have to wait a week and no S&H charges... check with your local store...
what are they like to install?
lol, some of the bushings (strut bushings) are easy to install, while the others (control arm) requires you to press the bushing in with a machine or McGyvver-style
in short, my friend, a bitch!
im not that experienced in DIY projects (the most ive done is taken my head unit out), do you think i would/should do it? or should i take it in to get it done for me
Get it done, I'm a huge DIY'er and I still paid to have mine all installed by a certified mechanic with a lift and air tools while he installed my sways, ball joints, and coils and he cut me a break on labor because he had it all apart already, but it still took him 10 hours total to do everything, and he only charged me for like 6.5 or 7 hours of labor. But it was well worth it, because he had the car in the air, the air tools and a press to press all the bushings in, should only cost like $150-250 labor depending on where you go.
Agree. Have it done properly at a good shop. Before you do so, gather some small suspension mods (sways, struts, underbrace) and do everything at the same time. The shop will most likely give you a break with the labor (everything is apart already). Save some $$$.
Ballin' on a budget, yo! lol
2012wagon
Sep 29, 2015 04:21 PM
Mugen TSX
Eastern Canada
Sep 1, 2015 11:11 PM
I'm def doin that right now
