My Break Light
My Break Light
Has This Happened To Anyone? My Brake Light Doesnt Turn On, Which I Thought Nothing Off, Thinking I Just Needed To Replace The Bulb, But I Have And The Brake Light Still Does Not Turn On, What Could It Be?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Do you have a spoiler? If you do, then the wiring doesn't hook up to the 3rd brake light, or is this one of your brake lights in the tails?
(Mid-Atlantic)
(Mid-Atlantic)
Is your brake light bulb indicator on your gauges lit?
Could be a loose wire, or your brake switch under the pedal could be stuck, but that would cause both, not just one side.
Originally Posted by saiko_cl_duck
loose/bad wiring or a bad bulb.
Originally Posted by kukicl300
WELL I TRIED 2 DIFFERENT BRAND NEW BULBS AND STILL NOTHING SO THATS HOW I KNOW ITS NOT THE BULB
Well, you've narrowed it down to wiring then.
Break out the multimeter.
You're gonna have to search for the wiring diagram and shoot the wires going to that brake light.
But first, look around the inside of your trunk where the wiring for that light is. If wiring is going to break, it's usually inside the area that gets the most vibration/ movement, and for the brake lights, that's the trunk. Look at the connector too, see if the pins inside look bent or uneven in any way.
(Mid-Atlantic)
(Mid-Atlantic)
do you mean a test light?
Originally Posted by subbuzz
is it one or both? also the new bulbs your using,do they have 1 or 2 contacts on the bottom?
(Mid-Atlantic)
(Mid-Atlantic)
They have 2 contacts, cuz they're dual filament
there is two thing, one is the wire and two it the fuse, because before i play around with my lexus and up mess up the light, i thouht the same thing just need to replace a light, but it turn out i blow up the fuse which only cause 1 dollar to replace. get those tool where it tell you if electricity is going to the load.
unpimp mein auto
hey, goddam wiring probs, i blame the british...anyway, im thinking you need a sub-harness(aka socket, i guess) back there, that was my remedy when mine was eating bulbs every second day
good luck bro-sef
good luck bro-sef
4x4- fat chicks cant jump
make sure youre replacing the right bulb. it sounds dumb, but hey... there are 3 or 4 different sockets there, i think its the top one, if that makes sense. i believe its the 2057 bulb.
thanks for the help, but some how i fixed the situation, my friend came over and started messing with the cables and we put another new bulb and WALAHHHHH...... dont know exactly how but it works!!!!!!!!!
(Mid-Atlantic)
(Mid-Atlantic)
Glad u fixed it, I had a problem with water in the bulb socket, but sounds like u just had a loose wire. Glad it was an easy fix.
Sounders FC
Oh and just got back from helping rebuild New Orleans as well partying at MARDI GRAS!
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
