my aircon smells like....!!!
05 STi White/Gold
some kind of animal crawled up in my aircon and died. it stinks... kind of a musty yet nasty smell. does anyone know how to get rid of this? do we have an aircon filter that needs to be changed??? any help would be greatly appreciated. thank!
Not Fast But Built 2 Last
If you use the AC on recirc alot, you might try shifting it over to fresh for a while before you park and shut down. Recycling the same air gets musty after a while and even the moisture from your breath stays in the car.
Lysol it
Get a can of Lysol, turn on your AC fan on high (not recirculation) and spray the lysol in the outside AC vents, where the air enters the cabin. Empty the entire can. It will kill any mold/mildew you have growing in your AC. And as said above, let you vent (AC off) run about the last 5 minutes before you shut car off. This will prevent any moisture from setting up inside the AC and causing the mold/mildew to form.
05 STi White/Gold
Originally posted by keuka1
Where are the AC vents on the outside located on a 98 CL?
I've got the stink too. My car has been "funk-a-fied!"
Re: Lysol it
Seminole Fan
I have the same thing happen to my ac when I ride around for a few days with the windows down without using it. Then once I turn it on it smells awful but it goes away after a few minutes. I think I might try something like the Lysol method mentioned earlier.
You know him right?
the flavour spelling is for you some1
Maybe the "funk" in your car is from you...take a shower once in a while!!!
Just kidding around. I found that a dryer sheet like bounce under the passenger seat does wonders for getting rid of orders.
But I'll try the shower too just to be on the safe side!
You know him right?
Those dryer sheets work wonders for alot of things...I used to put one in my hockey bag and it kept everything smelling pretty good.
CheeseyPoofs McNut
10-11-2015 11:25 AM
