msd ignition and coil
AWD Torque Monster
i came across a good deal on a fairly new msd 6al ignition and blaster ss coil so im thinking of picking them up. anyone use an aftermarket igntion or coil? im thinking maybe i just use an msd coil over the oem one and use the oem ignition. any tried just using an aftermarket coil? it would be like a $50 mod to do that and eveything would be brand new. not many ppl have too much info about msd igntions on hondas and if they do most of them are using the oem coil so are really not benefiting much at all. and most of those using both coils and ignitions seem to skip on opening the gap on the plugs which also severly decreases the benefits. then u got those ppl installing the igntion in hot places wondering why they are on their 3rd one. i just want some real facts. msd seem to be the most reputable with igniton parts/
-S namyaC-
Check with Comptech Mike. They list ignition on the list of mods on many of their cars. They show quite a good gain on the J30. I bought this up before, but I got the usual "stfu, you suck, I like my OBX exhaust idea, blah blah". I had planned to change the ignition on my car, but we'll see how long I end up keeping it.
A-CL Totaled Member
the 2.2 has a distributor cap for the aftermarket coil. i have a 2.3 so when i installed mine i had to make a custom cap which was a pain.
mine is mounted here:
niedejb has an igniton install on his site http://home.insightbb.com/~niedejb/
AWD Torque Monster
msd now has a cap for the 2.3cl go check their site.
i guess i will call msd. i was thinking of just pickin up a coil and cap from them. it would be a cheap mod and result in better mpg most likely. now all i need to know if a can use the msd coil with the oem ignition. i really want to get a masd ignition and coil.
i know if its installed right and u gap the plugs correctly their is decent mpg gain, way better throttle respionse, better start up and idle, and should be a small gain in power throughout rpm range.
thansk for the input guys
A-CL Totaled Member
you should be able to run just a coil. the box controls the signal and changes the degrees of rotation of the spark and what not. i'm not sure running just a coil will do too much. when i installed my ignition i got a tiny bit better fuel economy and the engine felt smoother up around redline.
A-CL Totaled Member
im sure if you put the part # in summit they p[rob have it. should eb like $30.
i did, they dont, i think they can get it if i call them though, thanks
"FROGGYSTYLE"
i am running a msd ignition with a msd blaster 2 coil and you can tell aa noticable change in the cars attitude. and i know that it gives off alot of spark because i was doing something under the hood and someone called my name and my hand hit the blaster coil top and shocked the piss out of me
Acura604
20
08-05-2017 12:55 AM
