MAP sensor
MAP sensor
i was have problems with my idle running between 1000-1500 in park. When I go to disconnect the map sensor. It seems to run normal.
Any my ideas of what could be wrong. Should I buy a new MAP sensor?
My 97 3.0 is doing this exact same thing I just replaced the IACV with a new one I bought on eBay and it's still doing the same thing? I've been reading its related to the IACV so I'm not sure if I got a bad part or if I need to replace the MAP sensor. I cleaned the throttle body well when I removed it.
Any help will be much appreciated.
