Made some new interior bulbs (pics)
I replaced all my interior lights with some high intensity LED's. The pics dont really capture brightness of the bulbs but trust me there 100X brighter than the standard bulbs.
The first pic replaces the map lights.
The second pic replaces the dome light.
The third pic replaces the door lights.
Yeah really, I want some, but my friend did that in his Rodeo and they shorted out so be careful. Where can I get those and exactly what parts did you get? Also how hard was the install?
Gimmie my points Biatch!
Originally Posted by legendaryCL98
dang.. that looks hot! u gonna teach me how to do that xxx?
we should have a DIY class every month.. everyone shares something new they learned how to do.. lol..
nippon_wa 2.0
this is the EXACT SETUP I HAVE TO DO FOR MY LED SIDE MIRRORS!!!!
YOU SHOULD TEACH ME HOW TO DO IT!!!!!!!!!!!!!!!!!!!!!!!!!
and... Can I have a pix of back??
he's not spillin his knowledge!!!
hmm... it doesnt look too hard.. lol.. just a bunch of leds.. some chip thingy..
Its pretty easy to make but the LEDs can be expensive.
Things you need:
1. soldering iron
2. solder
3. sheet of circuit board
4. LEDs (ask your dealer for the brightest ones cause there are different types)
5. resistors
6. dremel tool (with sanding attachment)
7. hot glue gun
8. 18 guage auto wire.
The color of leds you use will determine how many you can put in series and will also determine the type of resistor you'll need. I had some help for the industrial electronics store I bought my supplies from.
I'll use my setup as an example: ONLY FOR GREEN LEDS...
When you hook up an led to a 12V source you need a resistor. For 1 led you need a 400 ohm resistor. I wanted to use as many LEDs as possible and for GREEN LEDs 3 is the maximum I could use in series.
The guys told me for 3 green leds in series you need to use a 80-100 ohm resistor or the leds will blow. The higher the resistor the dimmer the leds. I used an 82 ohm resistor for maximum brightness.
For other colors like red, blue, yellow etc... you might be able to put more leds in series with a different resistor. Apparently each color gives off a different voltage. But I dunno dis shit too technical for me
The dome light I made has 6 LEDs. What I did there was I put two 3 LED series in a Parallel configuration. So for Green LEDs for every 3 leds need a 82 ohm resistor before you add another 3 leds.
I dunno bout you guys but reading the shit I wrote is giving me a headache.
1. Ok what I did was use a hacksaw to cut the circuit board.
2. Grind down the tips of the LEDs. This will widen the beam of light.
3. The sequence of parts go as follows:
resistor-led-led-led (door lights)
resistor-led-led-led led-led-led-resistor (dome light)
For the dome light power to the 2 resistors and ground the 2 ends of the middle leds.
4. Solder the tips
5. use a hot glue gun to seal the back of the circuit board.
6. Solder auto wire to extend the connections.
Just view pics to help you assemble the circuit it shouldnt be too hard. Good Luck!
Here's a link that Legendary gave me hope it helps
http://24.96.59.129:8080/LEGENDtuner...s/LED/LED.html
nippon_wa 2.0
THanks xxx!! I gotta try mine out!!
but before that, i can have some pix of back?? cuz.. i will also connect 5~6 leds together.. and.. don't know how u make them that short.. and.. how u connect 5~6 leds together?? only one resistor?
Originally Posted by 99CL
Don't they sell bulbs with LEDs on them already?
WhatCanChuDoForMeToday?
get the LEDs off ebay.. they sells 100s for like $20? but yea, dont know how long those LED will last.. heard they dont last too long compare to the more expensive ones.. but then again, u still have like tons of them to replace the bad ones.. replacement might be a bitch.
Yo Nippon here are the pics of the back. If your gonna hook up more than three lights you have to connect the resistors on 1 power wire (the long wire) and connect the 2 center leds with the ground wire (short wire).
As long as you keep putting the power wire on the resistor you can have as many lights in series as you want. This is based on 3 GREEN LEDs with an 82 ohm resistor. Any other color may require a different resistor, you gotts ask the shop you go to.
The circuit board in the background is what I cut to mount all the resistors and LEDs.
In this pic the clear goo over top of the circuit is the hot glue. This is what I used to seal the back. Its basically protects the back of the circuit from touching any other metal surfaces so you dont short anything out.
Flap.
Originally Posted by nippon_wa
nice!!! thanks a lot xxx!!
and.. is that okay to use only 2 resistors for 6 leds?? will not be burnt?
gotta start it!!
gotta start it!!
just calculate the resistance needed with Ohm's law and everything will be fine
Promiscious Boy
or you can just go to www.autolumination.com and just buy them. i have them in my car from autolumination and they are bright as hell.
09-15-2015 06:44 PM
