low idle
low idle
I installed a CAI and never looked at the rpms before I did it and with it in it seems to be idling low (a little less than 1000). Also I noticed on the exhaust a black residue. I'm thinking the the engine is not burning the fuel completley so it's leaving the residue and that can't be good for my engine. Any thoughts
your car should idle at around 750 rpm.
when does the black residue come out of the exhaust?
if it's at full thorottle, then you're fine. it's just running rich as most cars tend to do.
if it's at idle, then have it checked out... it could be carbon buildup, rich mixture... etc. your check engine light should be on.
Originally posted by VXCL
my car idles at 4-500rpms?? any1 elses? runs fine though
in fact its been idling a little rough .. when i step on the gas and bump up the rpms to around 700 ( where the should be ) it is smooth again
anyone ?MaCe
Did you guys notice that the first mark on the tach is 500? You can't read anything between 0-500, so people assume that an idle of 750 rpm (normal) is 500 since it's halfway between 1000 and the mark between 1000 and 0.
DerrickW
Nov 15, 2015 05:52 PM
