light power steering??
Boost is increased at stop and low speed, and decreased as speed reaches preset level. If this is a new car, you may need to adjust to the steering effort.
On 4-cyl. Accords the PS boost provides for 6.6 lbs (max) effort to move the steering wheel w/ vehicle idling and stopped. This is effort at the outside rim of steering wheel. If your effort is less than this, there is no specified diagnostic or remedy that I could see in shop manual for 94-97 2.2 Accords.
good luck
good luck
what about high speed turning effort,i got too much play at high speeds that if i hit a bump the car will not continue straight rather feel like slipping to one side ...especially when your all out(like in a race or flooring it in general) then its hard to keep control of the vehicle
get an allingnment. that should help. as far as loose steering i have it too. doesn't bother me. just make sure you get that allignment. before i had my wheels alligned my steering wheel would drive itself left and right all it wanted. after the allignment things got better.
my radio fuse?....lol
i already did alignment on 3-26-08
but my steering wheel is not straight??,,,after alignment it was..then like two weeks ago it tilted to 12:30-1:00 position
my tires are good ALTHOUGH THEY ALL ARE DIFFRENT TREAD DESIGN,NOT LEVEL,BUT DESIGN..is that gonna do anything?
take it back. first time they did the same with me.
mike from annapolis
05-07-2017 08:21 PM
asahrts
09-04-2015 05:55 PM
