Leaking Transmission Fluid, From Radiator? Help!?
I have an 1999 Acura 2.3 CL, I have transmission fluid leaking, but it is not leaking from the transmission. It is leaking from a hose that goes from the transmission to the Radiator. Why does thos hose connect to the transmission?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
The tranny lines run through the radiator to cool the tranny fluid. Sounds like you need a new rad. Hopefully the metal tranny lines aren't damaged and it's just the rad. I replaced mine it wasn't bad at all. Now would be the perfect time to put a tranny cooler on those lines as well, to help prolong the life of your transmission.
(Mid-Atlantic)
(Mid-Atlantic)
http://www.acuraautomotiveparts.org/acura/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CL&catcgry2=1 999&catcgry3=2DR+PRE2.3&catcgry4=KA4AT&catcgry5=RA DIATOR+HOSE+(1)&ListAll=All&vinsrch=no&systemcomp= List%20All&vinnoT=&trim=&trans=&view=normal
They're actually cheaper than I thought
IBankMouse
06-13-2020 12:53 PM
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
