kyb question
Old Nov 22, 2003 | 09:44 PM
baka_t's Avatar
The movement has started
kyb question
anyone with coilovers reversed the perch in the rear??? i can see its welded so i didnt reverse it i put my coils back on and now all i hear is like rubbing really loud rubbing
Old Nov 23, 2003 | 10:41 AM
baka_t's Avatar
anyone???
Old Nov 24, 2003 | 10:32 AM
baka_t's Avatar
bump
Old Nov 24, 2003 | 10:37 AM
ATLcl98's Avatar
Atl/Mia reppin'
not really sure what you mean by reversed it: like installed it incorrectly?
Old Nov 24, 2003 | 10:42 AM
baka_t's Avatar
well some people reverse the spring perch to put sleve type coilovers on the car the kyb's have a lip part like stock ones but that is welded usually you can knock the stock one off and reverse the perch just wondered if anyone did that or just set the sleve of the coilover in the perch
Old Nov 24, 2003 | 10:27 PM
CLstunner's Avatar
for the koni yellows, the perches are separate so they can be flipped easily. i dont see a point in that for coilovers though since the actual spring doesn't sit on the perch. also, when i flipped the perches, it interfered with my rear brakeline, so my brakes were slightly engaged the whole time, so i had to flip them back. i don't think it would be worth it to cut them on your struts, if anything, it would give it more clearance to crank it down more. i had agx's too at first and i don't remember any problems besides bottoming out.
Old Nov 24, 2003 | 10:33 PM
baka_t's Avatar
for the rears did you just sit the sleve in the perch with the kyb's?
Old Nov 24, 2003 | 10:52 PM
CLstunner's Avatar
ya, they fit pretty snug. when u put you coilovers back in, did you put those rubber rings in too? that prevents your sleeve from bouncing around. mine broke on one side, so i had to zip tie it, otherwise it makes a knocking sound everytime i hit a bump.
Old Nov 24, 2003 | 10:56 PM
baka_t's Avatar
yah i got the o-rings in stupid sunks !! after i get my recon back on with the springs
Old Nov 26, 2003 | 03:32 PM
baka_t's Avatar
got the upper rubber lubed its all good now no squeaking
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
