K-Series First gen 2.3cl
Old 04-24-2009, 09:32 PM
  #41
mamdike311x's Avatar
This guys wants 3500 for everything 3200 without the extras
Product description
-K24a1 Shortblock (4 miles)
-K20a2 Cylinder Head (0 miles)
-Gude full port & polish for f/i (head package that consists of the full p&p on the k20a2 cylinder head and regrinded cams)
-K20a2 Oil Cooling System, K24 Shortblock was drilled and plummed (0 miles)-
-K20a2 Aluminum Oil Pan w/ oil bung for turbo welded (0 miles)
-Cometic Triply Layer Metal Head Gasket (0 miles)
-Hondata Intake Manifold Gasket (0 miles)
-k20a2 Intake Manifold (0 miles)
-Labor from www.hybrid-racing.com
-All misc sensors included
-TSX 6 Speed Transmission (8000 miles)
-RSX-S Flywheels
-RSX-S Halfshaft & Axles
-RSX Alternator
Extras:
RSX-S Transmission Casing
Brand New Exedy stage 1 clutch
Brand New Circuitwerx 36mm hub for 92-00 civic
Seeing some longblocks that are a8's a1's as well i dont really know the difference i know the a1 match up perfect with the k20a1 head
Old 04-24-2009, 09:55 PM
  #42
I think im going to stick with a2 or a3 or maybe a Z3
Old 04-24-2009, 10:18 PM
  #43
CL in lawnmower status
mitch14's Avatar
what else would you need to buy for the swap?
Old 04-24-2009, 11:03 PM
  #44
joe rocks c2s :D
a2ndragoon89's Avatar
take it, if it's as new as they say, that aint a bad deal. make sure you find a good shop to fabricate mounts + wiring and stuff.
  #45
I dunno i havent asked, im kind of undecided on putting a turbo on the f or swap in a k i dunno there are so many options and my mind keeps changing. I changed my HP goal from 225 to 300hp. Main concern is reliablility! but i really want to go fast
Old 04-24-2009, 11:41 PM
  #46
Custom User Title
Gnate's Avatar
that k would be nasty...
Old 04-24-2009, 11:59 PM
  #47
2600lb CL
Cocoa's Avatar
That's a steal. Jump on it.
Old 04-25-2009, 10:15 AM
  #48
South Jersey CL's Avatar
oooo a six speed
do it
Old 04-25-2009, 01:54 PM
  #49
Dicorp's Avatar
you referring to the head?
a2 is RSX-S
a3 is Civic SIR Hatch
z3 is Civic SI
i'd go with an a2 because it doesn't have the Drive By Wire Throttle like the z3 does.
the a3 has the the single lobe vtec, you don't want that.
Old 04-25-2009, 07:01 PM
  #50
anyone here have an opinon on the g23?
Old 04-25-2009, 07:25 PM
  #51
Old School Ridin Clean
WineRed2.2CL's Avatar
3 gs for that setup is a steal. If it is true though.
I would jump on that any day.
Old 04-25-2009, 07:26 PM
  #52
but like many say you'll have to do major modifications. which will cost a bit more. so is 3 gs all it is?
Old 04-26-2009, 06:27 PM
  #53
i like acura
spencer_homer's Avatar
its possible. but you need to have the head milled( minor shaving)
Theres a few other make shift mods you have to do.
its more money than its worth.you can just get an h22 cheaper now
unless your going to boost. its a great project for boost.
Old 04-26-2009, 07:44 PM
  #54
DaInFaMMuS1's Avatar
Hell yeah it is. Dudes on H-T got 300+ hp on only 8 psi w/that motor. Thats beastly.
Old 04-26-2009, 08:11 PM
  #55
i like acura
yeah it really makes me want to do it. and its a lot more unique than a k24/20.
but not in a cl. a k would be just as cool.
Old 04-26-2009, 08:27 PM
  #56
i like acura
i think this has been posted before but this is a cool article.
http://www.importtuner.com/tech/impp...dge/index.html
Old 04-26-2009, 08:38 PM
  #57
where is....
AznX TL's Avatar
stay away from the k24z3, i have that right now. i hate the head design because its incapable with other k-blocks for a headswap.
and you can definitely find 7th gen accord k24 blocks for 2k w/transmission and ecu now.
Old 04-26-2009, 08:39 PM
  #58
f22vtec's Avatar
yep i did spencer, when im done with school and still want the cl i wanna do that swap or boost the f motor. ive come to the conclusion that right now isnt the best time for me to be spending that kind of money so im just doing looks.
Old 04-26-2009, 09:18 PM
  #59
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,461 Likes on 3,055 Posts
buy it
Old 04-26-2009, 11:05 PM
  #60
LostSpecter
Specter's Avatar
I heard the K24 sits more infront of the engine bay. So you'll make your CL more front heavy
Old 04-26-2009, 11:16 PM
  #61
Dicorp's Avatar
well it is rotated 180 degrees compared to an F or H. thats why probably.
Old 04-27-2009, 12:32 AM
  #62
LostSpecter
Specter's Avatar
Ah it is true. I'll stick to my H22 plans.
Old 04-27-2009, 09:17 PM
  #63
JDM ALL OVER
9seven-wHite-CL's Avatar
if u got the money do it!
sohc f22 ftw!
Old 04-28-2009, 12:15 AM
  #64
Dicorp's Avatar
meh, that article sounds iffy. sure you can make it all work, but it's complicated. just swap the K or the H.
Old 04-28-2009, 08:35 AM
  #65
(Mid-Atlantic)
Originally Posted by 9seven-wHite-CL
sohc f22 ftw!
Old 04-28-2009, 01:22 PM
  #66
i like acura
yeah its complicated.but i bet if you got ahold of the guy that did it, or one of the guys that has successfully, it wouldnt be that hard to figure out the tricks and trades of this swap
Old 04-28-2009, 01:30 PM
  #67
i like acura
^ oh and i really like how they mentioned the f.
and how k pistons can be used in the F block. i guess you could call it iffy, but that would make for ONE BADASS N/A CL
Old 04-29-2009, 12:38 AM
  #68
i like acura
k20's arent that bad...if you pick up the whole car wrecked. ive found totaled rsx's for 1100-1200. id get the 20, with the 6 spd. then get a 24 block before the swap
Old 04-29-2009, 02:11 PM
  #69
Dicorp's Avatar
the amount of people attempting a g23 on PP.com is significant and the amount of sucessful swaps is minimal. It's a hard swap. Ask Dainfammus or Silver97CL.
yes the potential is amazing, but you'd have to set your car aside for months while you build this engine piece by piece. H is a direct swap, a K not so much but still a functional engine from the get go.
anyways, this thread is about Ks. Let see where he goes with this.
emailnatec
29
09-28-2018 04:27 PM
GWEEDOspeedo
01-15-2016 10:39 PM
RSpyder
09-30-2015 12:46 AM
Quick Reply: K-Series First gen 2.3cl
