JDM Prelude shifter assembly question...
Old Dec 12, 2006 | 12:58 PM
acuratl_2nr's Avatar
After looking around for a lude shifter for the past 6 months, I have finally found one! I got my hands on a 94 JDM Prelude SR-V shifter assembly with the plate and everything. My question is can I just remove my stock shifter and shifter plate and just bolt up the Prelude one? Or do I absolutely have to use my stock CL shifter plate? I know there was some clearance issues with the CL plate and Lude shifter hitting metal plates, I was thinking that the Lude shifter plate would eliminate that problem... Someone must have some intel on this. I will only be installing it next week after finals...
here are some pics of the assembly
Old Dec 12, 2006 | 01:10 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
re post the pics, they dont work
Old Dec 12, 2006 | 01:14 PM
here they are again....
Old Dec 12, 2006 | 01:55 PM
732xghost's Avatar
ooo prelude srv sexy
yea i would like to know this too, because i might in fact get my hands on a prelude shifter from 94 as well. a guy at work is putting a short shifter on his.
Old Dec 12, 2006 | 02:23 PM
klepto's Avatar
it looks like it should bolt up. compare those pics to the ones I took in the shifter DIY. you wont know until you actually try though, but its not that bad to take apart your center console and see wassup.
Old Dec 12, 2006 | 02:29 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
cool shift knob
Old Dec 12, 2006 | 02:56 PM
I was looking at the DIY and I was wondering, do you guys have pics of the small shift collar you had to buy off of www.hondaautomotiveparts.com ? Or can you describe the piece? Is it just a rubber collar that goes on the screw before you slide it on to the shift cable?
Old Dec 12, 2006 | 03:25 PM
Shoshinsha_KiDs_CL's Avatar
sold!
nice and low
Old Dec 12, 2006 | 04:27 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
its metal.. just order the part, ull need it
Old Dec 12, 2006 | 05:07 PM
klepto's Avatar
its basically a really small metal cylinder that goes inbetween the two metal pieces. Then you slide the bolt through it. It helps to makes the shifts smoother.
Old Dec 12, 2006 | 05:18 PM
VaTECh_CL's Avatar
Let's go Hokies!
I'm pretty sure it won't bolt right on. I had the same situation and the prelude base just isn't as long as the CL shifter base so it doesn't work out. I was all excited that i wouldn't have to switch that out but when i got it appart it didn't fit right. you can always try, just make sure to leave enough time in case it doesn't work.
Old Dec 12, 2006 | 05:30 PM
I think i'll be able to get the sleeve at home depot or something,.. it sounds pretty basic. As for the plate not fitting, it's not that big of an issue all I want is the shifter, if it fits then good but if it doesn't it's just a little more work. Thanks for the responses btw
Old Dec 13, 2006 | 02:06 PM
I ordered the sleeve from the dealer, I posted the part number and I'll post a pic of it tomorrow in the DIY forum to help future modders
Old Dec 22, 2006 | 06:15 PM
I updated the DIY with a little more information...
TypeS860
Jan 10, 2026 11:11 AM
Jul 16, 2017 07:33 AM
MikeJM310
Sep 24, 2015 07:24 PM
