Info on CL
Info on CL
FAQ 1st Gen (1997-1999)
Must Read before posting!!!
Taken from members and thread around this forum. Give me your nickname and I'll credit your info.
Stock :
2.2 CL 145 hp / 147 lf/Torque
2.3 CL 150 hp / 152 lf/Torque
3.0 CL 200 hp / 200 lf/Torque (only in 4 speed AT)
Bolt pattern : 4 X 114.3
Modification :
<table>
<TR> <TD>Exhaust :</TD> <TD>2.2 /2.3 CL</TD> <TD>3.0CL</TD></TR>
<TR> <TD></TD> <TD>Anything that fit Accord 94-97</TD><TD>same as 2.2/2.3</TD></TR>
<TR> <TD></TD> <TD>DC Sport </TD> </TR>
<TR> <TD></TD> <TD>A'PEX</TD> </TR>
<TR> <TD></TD> <TD>Greddy</TD></TR>
</table>
Exterior :
Wing West Type R Lips
Wing West Type R Wing (rice):-P
Maintenance info :
Repair Manual :
http://www.acura-cl.com/forums/showt...6&page=8&pp=25
Reset Engine Code :
Disconnect the battery or remove the backup radio fuse
Stock :
Modification :
<table>
</table>
Exterior :
Maintenance info :
Repair Manual :
Reset Engine Code :
roomate has a CL too
add obx to exhaust.
2.3 gets 2.25 inch custom piping.
3.0 2.5 inch custom. for normal modifications NA
and the 2.3 gets 2.5 for FI applications
h22 is direct swap into the 2.2/2.3
intakes for 3.0 is 98-02 accord v6
intake for 2.3 is 94-97 accord v4
I believe prelude 4th and 5th gen work perhaps not the best fitment but works
short shifters for 2.2/2.3 are 4th generation VTEC or Si prelude stock shifters. or p-spec or forbidden(4bidden) racing... stock shift knob can be used.
mirrors from I believe a 94-97 accord fit onto our cars with the drilling of an additional hole... I'm not sure on this someone confirm please.
there is way more stuff Im sure scott already has this stuff in his new n00b guide.
Stock :
Modification :
<TABLE BORDER=2>
<TR> <TD>Exhaust :</TD> <TD>2.2 /2.3 CL</TD> <TD>3.0CL</TD> </TR>
<TR> <TD></TD> <TD>Stock : 2.25 inch</TD> <TD>Stock : 2.5 inch</TD> </TR>
<TR> <TD></TD> <TD>FI : 2.5 inch (recommanded)</TD> <TD>???</TD> </TR>
<TR> <TD></TD> <TD>Anything that fit Accord 94-97</TD> <TD>same as 2.2/2.3</TD> </TR>
<TR> <TD></TD> <TD>DC Sport </TD> <TD></TD> </TR>
<TR> <TD></TD> <TD>A'PEX</TD> <TD></TD> </TR>
<TR> <TD></TD> <TD>Greddy</TD> <TD></TD> </TR>
<TR> <TD>Shifter :</TD> <TD>4th gen. VTEC or Si prelude stock shifters</TD> <TD></TD> </TR>
<TR> <TD>Header :</TD> <TD>Accord 94-97 I4</TD> <TD></TD> </TR>
<TR> <TD></TD> <TD></TD> <TD>Comptech (1200$) Direct Fit</TD> </TR>
<TR> <TD></TD> <TD></TD> <TD>OBX (300$) Not Direct Fit : should be bend.</TD> </TR>
<TR> <TD>Suspension :</TD> <TD>Accord 94-97 I4</TD> <TD>Accord 94-97 V6</TD> </TR>
<TR> <TD></TD> <TD>Eibach pro kit</TD> <TD>same as 2.2/2.3</TD> </TR>
<TR> <TD></TD> <TD>Neuspeed Sport Spring</TD> <TD></TD> </TR>
<TR> <TD>Lightning :</TD> <TD></TD> <TD></TD> </TR>
<TR> <TD></TD> <TD></TD> <TD></TD> </TR>
<TR> <TD>Motor :</TD> <TD></TD> <TD>J30A</TD> </TR>
<TR> <TD></TD> <TD> </TD> <TD> </TD> </TR>
<TR> <TD>HP / Torque :</TD> <TD>2.2 CL = 145 hp / 147 lf/Torque</TD> <TD>3.0 CL = 200 hp / 200 lf/Torque (only in 4 speed AT)</TD> </TR>
<TR> <TD></TD> <TD>2.3 CL = 150 hp / 152 lf/Torque</TD> <TD></TD> </TR>
<TR> <TD>Swap :</TD> <TD>H22/H23 (direct swap)</TD> <TD>J32A + 6 speed swap ( 7k-10k)</TD> </TR>
<TR> <TD>Intake :</TD> <TD>Accord 94-97 I4</TD> <TD>Accord 98-2002 V6</TD> </TR>
<TR> <TD></TD> <TD>AEM with water bypass</TD> <TD>same as 2.2/2.3</TD> </TR>
<TR> <TD>Tire :</TD> <TD></TD> <TD></TD> </TR>
<TR> <TD>Bolt pattern : </TD> <TD>4 X 114.3</TD> <TD>same as 2.2/2.3</TD> </TR>
</TABLE>
Exterior :
Maintenance info :
Repair Manual :
http://www.acura-cl.com/forums/show...66&page=8&pp=25
Reset Engine Code :
Stock :
Modification :
<TABLE BORDER=2>
</TABLE>
Exterior :
Maintenance info :
Repair Manual :
Reset Engine Code :
Need help to complete missing info on Coil Over, lower, strut, etc bar.
thx
I reupload the FAQ.
Need feedback good or bad.
HERE WE GO :
Http://www.novaciel.com/acura%20repair/acura.html
thx
I reupload the FAQ.
HERE WE GO :
MrHeeltoe
20
02-23-2023 01:54 PM
rcs86
08-02-2016 06:52 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
