I Need Help!!!!????
Always drivin 100+
I Need Help!!!!????
Man I am at a total stand still trying to figure out why this motor won't fire up. I am running a JDM h22a with the original JDM internal coil distributor. The wire harness I used is from my F22B1 original motor with sensors and wires lengthened. The distriputor wiring was crossed refrenced and wired up to accomodate the difference in years. We know for a fact the distributor wiring is configured right. I am also using the JDM P13 ecu that came with the motor. Since my car was OBD2, i purchased a wiring harness that converts my OBD2 to an OBD. At this point, I am basically looking for some troubleshooting steps I could take to determine why the motor turns over, but I am not getting any fire to my plugs.
Advice thus far:
1. Could be the ignitor or internarl coil, may need to replace either or or both.
2. May have to convert JDM internal coil to US external coil from a 93-95 prelude.
3. Check the OBD2 to 1 Conversion harness and make sure pins/wires are in correct place.
Question:
How in the world does one hook this JDM distrutor up to work? Am I missing something?
Advice thus far:
Question:
