i gave up on searching
1 Post
after 17 minuts of looking through old threads and searching, i have given up. if its a repost someone PLEASE redirect me.
my question.. is what would be needed to increase the redline of my f23? as most of you know.. there isnt a single drop of power until 3k rpm, and by the time your at 6, the Sienna has passed you.
basically, id like to be able to stay in each gear a little longer, an 8k redline would be nice, but what would i need to upgrade? obviously ECU/software, what can our ignition system handle? fuel pump? internals?
i like acura
youd probably just want to do basic mods for power before you start lookin to extend your redline for more gear. without internals, i dont think the motor would take it. mine feels like its gonna blow at 6500
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
U could also change the vtec engagement point
Ciao Pho Eva eva
17 mins really.. u gave up that quick? u think modding cars is that easy..
well to answer ur question, you would need to get a piggyback system ECU system (aem, gredddy) and get it tuned..
BUT the redline is set for a reason.. u think 1000 japanese people (or guys from Ohio) spent all that time so u can shift at a later RPM with a 17 min search?!!?? .. EVEN WHEN u know that no power is made after redline..
i like acura
exactly!
(Mid-Atlantic)
(Mid-Atlantic)
17 mins isn't much, considering there are TONS of threads on this subject
1 Post
... considering the search system here, and the fact that you have to wait 60 seconds between searches.. i think 17 minutes is a good deal of time. especially considering that when you type in a word/words, acurazines brilliant search feature suddenly cuts out half of them in an attempt to thin our your results.
And spencer, i have I/H/E already, trying to sort out the next step to go in power wise.
If I got new under pulley & engine management//tune, what could i expect out of it?
(Mid-Atlantic)
(Mid-Atlantic)
2 more hp on the butt dyno
Custom User Title
yeah dude you really make no power after redline in an f anyway, so why would you bother? Get a stage 2 bisimoto cam, it focuses on like 1700-5800 rpm or some shit like that, its perfect, and valvesprings and lifters are only suggested. I talked to a guy on who dropped that cam in by itself with just a tune and he said it was a blast.
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
(Mid-Atlantic)
(Mid-Atlantic)
Ciao Pho Eva eva
the only cheap option left power wise is to spray.. but i wouldn't recommend it..
Edit: underpully isnt going to help much either lol.
Originally Posted by Anhedonia
^^ my parents took me off the bottle when i was real little, dont plan on revisiting it any time soon.
thanks all, looks like ill start saving
and nitrous really isn't bad at all, especially if u were to go N/A and wanted a little extra juice when u needed it, nitrous likes high compression. Its also quick, inexpensive power unless you are a nitrous whore and constantly use it.
If you are thinking about putting in a bisimoto cam think about getting an h23 IM and a good throttle body too. For the f motor you can use the stock h23 IM as a performance IM for our motors.
1 Post
good info vtec, and infammus, for the setup nate was talking about. The only reason id want to go with nitrous would to be if i was taking her to the strip, which im not so right now it looks kind of useless. Im looking for more constant power then one time use.
and im not going to lie to ya... n/a h series are better than n/a f series. mod for mod, h will always win. you can build up your f23 to kick some h22 ass, but you will end up spending way more money building up your f23 to match an h22.
not that im against All motor F's... i actually dreamed of building an all motor f22. it would be insanely cool, but not having money is a big factor against building one.
MMkay.
i wudnt even think about changing the redline man..
even if u KNOw that theres no power after..theres no point in straining the engine..changin when ur vtec kicks in can probabli mess with ur engine too..im almost positive..they made it last those couple grand of revs for a reason..getting an ecu and all is pretty expensive too..i wud do as much bolt ons as possible before really messing with ur engine that much..
just my
just my
1 Post
just my![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
just my
ive bolted on everything to be bolted on, minus a cam gear and a tune. my next step for a NA build would be a bisimoto cam and most likeley hondata. but as you can tell, im looking into FI
then you have to get a different cam not the one gnate suggested if you want to go boost. You can't get it tuned either unless your obd1 or have an apexi vtec controller which matt says doesn't work on an F or you can go the hondata route and honestly you're probably not going to get the cam and tune anyways lol. Just keep it how it is throw some wheels on it and do inexpensive exterior mods for now and get something you really want when you're done with school.
If you want more power, go for it. I'd say just be sensible in power for the money. Pick a direction and follow it, either boost or N/A. Cam regrinds aren't cheap so if you're gonna get 1 make sure it's the one you want, unless you have the money to throw away in changing things. If you're going boost, get a turbo cam, and build up your turbo kit. I recommend Treadstone Performance for a relatively affordable kit that comes with good brand name parts. As for tuning, a vtec controller wont give you the flexibilty you need to tune your turbo F, so either Hondata, Neptune, or AEM EMS would be my choice. My cousin's used AEM EMS on countless cars for his shop and says the flexibility is awesome, thats what his 890 hp s2k runs on right now. If you're on a tight budget, get obd2 to obd1 jumper harness, a p28 with neptune and/or crome programmed onto it and you'll be able to tune the car with that, thats what mine is tuned on currently till i go turbo and get Hondata or AEM. Besides, if Jeff Evans can tune cars the way he does with Neptune, i'd say its pretty damn capable.
just my
just my
yea BUT you're 25 we're 19 and 20 lol do you work full time? I would hook my shit up too. Im saying for us we're trying to hook up our cars but we're young and broke and always having to pay for school or bills. It's nearly impossible for us young cl'ers to save for the big things i got all my parts dirt cheap from matt lol.
and hey i've gotten my fair share of compliments and stares too lol. I think compliments and stares are the product of a sexy appearance hence why you get stares too know body has a black cl with rotas and yellow headlights. I mean hey we all have to drive the speed limit most of the time so people don't know if we're fast or not anyways. Thats why if i keep the cl when im done with school and want to really do work to it it will be perfect timing my motor will be on its way out and I'll be making good money i hope..
1 Post
1 Post
Im double majoring right now, trying to add a third. if not, ill take a minor and a double. i too plan on getting my masters in hopefully two of my majors.. but we will see.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
