i found a cheap hub puller
http://www.thetoolwarehouse.net/shop/LT-825.html
for those of you that want to change your front rotors thsi tool will make it easier.
my guess is after you pull the axel out. you put the hub puller were the axel gues and pound on it instead of the hub itelf?
but im going to get one. i tried to replace my front rotors i got had everything apart but was to afraid to pound the hub because it was sunday and i need my car to go to work.
ENGAGE MY VTEC BABY!!!!!!
you have to be careful cause the bearings are hella expensive for the fronts, i had to replace mine about 2 years ago when they did my fronts, they were like 80-90 each
STL TL-S
09-23-2015 08:52 PM
